Need to settle a bet...easy question...
Old May 19, 2004 | 09:25 AM
01ITR#700's Avatar
Default Need to settle a bet...easy question...
I'm stuck at work and need to settle this easy question...
Does a '93 Civic EX coupe 5-speed have VTEC? The owner of the car swears up and down that she does not have VTEC but I'm pretty confident she does.
Thanks a lot!
Mark
Old May 19, 2004 | 09:27 AM
Team 4's Avatar
Default Re: Need to settle a bet...easy question... (01ITR#700)
Yes, it has the SOHC VTEC D16Z6 motor. It just might not say it on the valve cover.
Old May 19, 2004 | 09:28 AM
skip.two's Avatar
yes, it is equipped with VTEC.
the motor is a D16Z6 SOHC VTEC.
Old May 19, 2004 | 09:32 AM
CivicHatchback14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REVHARD_EF &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it has the SOHC VTEC D16Z6 motor. It just might not say it on the valve cover.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">yes, it is equipped with VTEC.
the motor is a D16Z6 SOHC VTEC.</TD></TR></TABLE>
WHAT THEY SAID
Old May 19, 2004 | 09:39 AM
01ITR#700's Avatar
Default Re: Need to settle a bet...easy question... (CivicHatchback14)
Thanks for the quick responses guys.
I'm on the phone with her and she did verify that it's a D16Z6, but claims she cannot see the VTEC solinoid and has never heard VTEC and she also claims her friend that works at Honda said it does not have VTEC either??
FWIW she has a short ram intake and some kind of muffler so I assume VTEC should be realtively audible correct?
Thanks again.
Mark
Old May 19, 2004 | 09:42 AM
skip.two's Avatar
the vtec solenoid is near the upper left side.
since it is a SOHC VTEC, you will not really hear it like a DOHC VTEC.
with just those mods, i dont think you will hear it.
Old May 19, 2004 | 09:43 AM
From: eating the shit out of pizza in raleigh, NC, USA
vtec isnt loud at all on the z6 motor. so, you probably wont hear it too good....
Old May 19, 2004 | 09:45 AM
GregDelSolSI's Avatar
Is the D16Z6 1.5 or 1.6, and when should VTEC kick in?
Old May 19, 2004 | 09:46 AM
01ITR#700's Avatar
Default Re: Need to settle a bet...easy question... (2ndchancehonda)
Cool, yeah she verified it was a Z6 and I was telling her where to look for the Vtec solenoid and I described it as best I could asn she claims there is not solenoid. Her Dad bought the car new so no funky non VTEC head swap was ever done, that I know for sure. I guess I'll go take a look at it after work and collect my $50
Thanks again.
Mark
Old May 19, 2004 | 09:47 AM
01ITR#700's Avatar
Default Re: Need to settle a bet...easy question... (GregDelSolSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GregDelSolSI &raquo;</TD></TR><TR><TD CLASS="quote">when should VTEC kick in?</TD></TR></TABLE>
Good question, I'll take her for a ride and point this out for added backup.
Old May 19, 2004 | 10:21 AM
PokeyD16Z's Avatar
VTEC on the SOHC is more audible with just an intake. The exhaust kinda quiets it down a bit. But, you should still tell. It comes in at 4800 rpms and its characterized by have a sound like air being sucked in before 4800 rpms, and then it sounds like its not sucking as much. Listen carefully. And, yes, all 5th gen EXs had VTEC on the Z6. There will be the solenoid and depending on the year, VTEC on the valve cover. The solenoid has a nasty green color cap on it.
Purple_Civic
Apr 8, 2005 11:14 AM
whitehf
Oct 1, 2004 09:26 AM
HondaVTEC93
Aug 10, 2004 02:39 PM
hondaracing1
Dec 25, 2003 02:47 PM
99lsvtecauto
10
Oct 12, 2003 11:35 AM
