Turbo Parts LIST "List your turbo kit"
Old May 18, 2004 | 08:15 PM
AL ASPIRATED's Avatar
Default Turbo Parts LIST "List your turbo kit"
can anyone list what is EXACTLY everything needed to part a turbo kit together? I tried searching but can really find everything.
Im looking for fittings, flanges, gaskets, lines, etc.....
hers a start of the list
turbocharger
turbo manifold
wastegate
oil feed line
oil return line
intercooler
intercooler piping
etc..............
THANKS for your help
also lets make this the "OFFICIAL TURBO PARTS LIST"
Old May 18, 2004 | 08:25 PM
AGS's Avatar
AGS
Default Re: Turbo Parts LIST "List your turbo kit" (AL ASPIRATED)
this might help... i looked at a bit of it, seems pretty comprehensive.
http://www.greddy.com/tech.asp
Old May 18, 2004 | 08:40 PM
jdm.ej's Avatar
some sort of engine management. bigger injectors, boost controlle,r turbo timer,
boost gauge,air/ fuel ratio guage,oil pressure gauge, and fuel pump would help,
and for flanges it all depends on what turbo you got and for wastegate some are internal and some are external.best wastegate to get is tial, if your not going to run any sort of em (which you really should either hondata or uberdata ) if not you need a missing link and fmu.
Old May 18, 2004 | 09:05 PM
Cruiser G's Avatar
Default Re: Turbo Parts LIST "List your turbo kit" (jdm.ek)
https://honda-tech.com/zerothread?id=373905 that might help a little
Old May 19, 2004 | 05:26 PM
ttt
Old May 19, 2004 | 06:17 PM
mugenwannabe's Avatar
TD04 turbo
high pressure fuel line for oil feed and return
dsm 390cc injectors
hf manifold
custom adapter plate
tapped oil pan
bunch of custom bent pipes
fmic
safcII
boost gauge
a/f gauge
vaccum lines
some t's
brass fittings to tap into back of block
check valves
custom downpipe
misc. gaskets
Old May 19, 2004 | 06:34 PM
onePOINTsix's Avatar
Default Re: (mugenwannabe)
Turbo of your choice (14b, T3, etc)
HF Mani and adapter plate
McMaster Carr oil lines
TurboEdit
Walbro 255lph fuel pump
some mandrel bends for charge pipes and dp
intercooler (one from a probe or dsm work good)
o0Jash0o
Nov 4, 2006 02:16 PM
Carson-EK9
Mar 16, 2006 07:53 PM
mongoliandonuts
Dec 11, 2004 09:30 AM
boosted89si
Aug 28, 2004 04:18 PM
Joel_MN
Aug 28, 2003 12:41 PM
