Differential help
Old May 18, 2004 | 07:56 AM
matix's Avatar
Default Differential help
Ok here is the problem i keep having problems with my passenger side axle popping out. I have replaced the axle 3 times and this isnt it. I noticed when i push the axle up and down it has leeway in the differential. The splines are ok so i dont think thats the messed up part. I took out axle and the peice were the splines go into moves up and down. I was thinking maybe its a bearing or something cause at high rpms(6k-7.5k) i get a bad vibration from the drive train. Also when i got this tranny the shop put a cm stage4 clutch on it and resurfaced my flywheel. What could be the problem do i need a new differential or is it something simpler than that.
Old May 18, 2004 | 12:51 PM
JDMotive's Avatar
Default Re: Differential help (matix)
what engine/transmission is it?and what axles are you using?Ive never heard of that kind of problem..are you making sure the locking ring is on the end of the axle?Maybe an olde ring got stuck in there and isnt letting the old ring grab onto anything...also..make sure the axle is all the way in,not just where it feels like its not going in anymore...it has to be flush and not much gap between the axle and the transmission.
Old May 18, 2004 | 12:55 PM
matix's Avatar
Its a h22 engine and tranny. I am using nappa lifetimes. It goes in but the is a litte space between tranny and axle. It has movment though once its in. It has to be pryed out once it goes in. Any other thoughts. The actual housing for the axle to lock into is what moves up and down. Sorry im new to transmissions
Modified by matix at 4:14 AM 5/19/2004
Old May 19, 2004 | 06:50 PM
matix's Avatar
no help.....
RanCRX
Transmission & Drivetrain
Dec 28, 2009 03:03 PM
RanCRX
rhdekhatchie
Mar 16, 2008 10:17 PM
JSpin
Mar 26, 2004 08:52 PM
DOHCon15s
Jan 14, 2004 09:30 AM
