Minor shop problem, any suggestions?
Old May 18, 2004 | 06:09 AM
xSCTYGx's Avatar
Default Minor shop problem, any suggestions?
Took my car to Midas about a week ago to get my overheating and idle problems fixed (I was too fed up with my car at the time to do any work on it..just sick of it) Anyways they do a diognistic and found out that it was my ground wire on my radiator fan, and that the vaccum hose that was leaking was behind the IM and under the brake booster...anyways, they wanted to do more "investigating" and charge me another 80 some bucks to dig deeper into the problem...so I said no, so they stopped. Get my car back to realize that my CD player won't even turn on. I call him the next day and tell him that it wouldn't turn on, and they said that the only thing they did was turn it off, yet it worked perfectly fine before then. He also mentioned that it was "my problem, not theirs" and that they weren't going to fix it...any suggestions?
Old May 18, 2004 | 07:22 AM
4dr_GS-R's Avatar
well it depends...is it an aftermarket cd player or a stock cd player...
cuz my stock cd player had code u had to put in everytime the battery was disconnected...before it would turn on...i dont know if there are many aftermarket cd players that have that...
well in anycase, hope everything works out for ya...
Old May 18, 2004 | 07:40 AM
xSCTYGx's Avatar
Default Re: (4dr_GS-R)
It's an Pioneer DEPH 3500 and it doesn't have a code...anymore ideas? LOL you don't know how borring it is to drive with no music!
Old May 18, 2004 | 10:28 AM
PlastikOwl
Guest
Posts: n/a
Default Re: (xDA9x)
check all your fuses?
Old May 18, 2004 | 10:38 AM
ekdriven's Avatar
yea when my cd player was sent out to get a cd taken out i was goin nuts i used portable speakers and disc man.
Old May 18, 2004 | 10:45 AM
IntegraBoy04's Avatar
Default Re: (xDA9x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDA9x &raquo;</TD></TR><TR><TD CLASS="quote">It's an Pioneer DEPH 3500 and it doesn't have a code...anymore ideas? LOL you don't know how borring it is to drive with no music!</TD></TR></TABLE>
Oh, I know how boring it is. I haven't had a CD player since I got my car back from it's wreck. About 1.5 months.
Old May 18, 2004 | 12:17 PM
xSCTYGx's Avatar
Default Re: (PlastikOwl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlastikOwl &raquo;</TD></TR><TR><TD CLASS="quote">check all your fuses?</TD></TR></TABLE>
How many fuses are there that run the cd player? Cause my clock lights up so I know it's not the one under my dash..
Old May 18, 2004 | 03:12 PM
xSCTYGx's Avatar
Default Re: (xDA9x)
bump
Old May 18, 2004 | 03:18 PM
dannylDAsport's Avatar
Default Re: (xDA9x)
does ur radio have a fuse behind it if it does check that. or u can go back to midas and talk to service manager.
Old May 18, 2004 | 05:02 PM
xSCTYGx's Avatar
Default Re: (dannylDAsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannylDAsport &raquo;</TD></TR><TR><TD CLASS="quote">does ur radio have a fuse behind it if it does check that. or u can go back to midas and talk to service manager.</TD></TR></TABLE>
No it doesn't and I was talking to the manager of that store. Read first post to see what he said.
Old May 18, 2004 | 05:08 PM
Sukebei Oni's Avatar
Default Re: (xDA9x)
go back and ask for the phone number of the district manager.
Old May 18, 2004 | 05:43 PM
Medek's Avatar
Default Re: (Sukebei Oni)
i hope those idiots disconnected the battery b4 operating on any ground wire. If not, they might have fried something in the wiring harness. any dash lights going crazy or not working properly? get a light tester (has a metal rod that looks like an icepick to stick to power and a seperate ground check the radio harness for power.
Old May 18, 2004 | 07:29 PM
xSCTYGx's Avatar
Default Re: (Medek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Medek &raquo;</TD></TR><TR><TD CLASS="quote">i hope those idiots disconnected the battery b4 operating on any ground wire. If not, they might have fried something in the wiring harness. any dash lights going crazy or not working properly? get a light tester (has a metal rod that looks like an icepick to stick to power and a seperate ground check the radio harness for power.</TD></TR></TABLE>
Every other dash light is fine...yea I need to do something, my friend is an electrician, so ill get him to check it out this weekend...any other suggestions?
Old May 19, 2004 | 05:57 AM
xSCTYGx's Avatar
Default Re: (xDA9x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">any other suggestions?</TD></TR></TABLE>
Lucky-13
Feb 23, 2007 05:40 PM
ch0
Audio / Security / Video
Sep 20, 2005 12:12 PM
FalconMan
Sep 25, 2003 05:52 AM
khny83
Sep 14, 2002 09:44 PM
