Weird CRX HF block
Old May 17, 2004 | 08:56 PM
onePOINTsix's Avatar
Default Weird CRX HF block
Hey all, i bought a bunch of parts from a friend, one of which was a D15B6 block from a 89 CRX HF. Looking at some of the part numbers and compairing those numbers to a CRX DX (D15B2) the pistons (duh, it's a 8 valve motor ), rods and crank have different numbers. Does this mean the rod lenghts and such are different? I don't have the abillity to drop the motor in my 91 Civic Std. (D15B2) and take it apart to compair sizes. Here's some pics:
Piston and Rod
PM8 Piston
Rod Closeup
PM3 Main Caps
edit: sorry for the clutter behind the pistons, rebuilding like 3 turbos and my motor building station dosent have enough light for taking pics
Old May 18, 2004 | 05:38 AM
tgreaves's Avatar
Default Re: Weird CRX HF block (Sideout)
I know as far as the blocks are concerned, they are the same.. The hf and dx cranks have the same size mains but not the same size rod journals..
Not sure about the rod length..
Old May 18, 2004 | 11:05 AM
Default Re: Weird CRX HF block (tgreaves)
ok I guess i will try to drop the engine in my Civic and I'll just use the crank and rods from it(te motor in my car is possessed i swear )
Old May 18, 2004 | 12:39 PM
more pics:
Block Code
Bottem of the block with crank:
Close up of the crank:
Old May 18, 2004 | 12:49 PM
tgreaves's Avatar
Are you looking for d15b2 pistons, rods, and a crank to put into your d15b6 block.. If so let me know, I have all of them cleaned up sitting in my room that I will let go cheap..
vtecn8ive
Jan 29, 2011 08:23 AM
vtecn8ive
12
Jan 28, 2011 08:01 AM
CRX1.4DualCarb
Dec 25, 2006 09:15 PM
dod
Mar 20, 2006 08:15 PM
tgreaves
Jan 27, 2004 12:36 PM
