90-93 Main Fuel Relay? or other ignition problems?
So I pulled it out because I think it finally went... what troubles me is that the car actually died while driving. Makes me think it's not just the relay. I had been having problems starting the car and that's why I thought it was the relay. Anyone that could enlighten me on this matter please? Is it possible for the car to just die because of the relay even if it is already running and has been running for 10-15 minutes?
Thank you in advance.
WOOOOOOOOOOOHHHHHOOOOOOOOOOOOOO!!!!
I was afraid it could be the coil or the fuel pump... I'll get the relay tomorrow and hopefully it'll start. Thanks!
Well... new relay, and $50 later, still no car. Any ideas? What should I look at next? Ignition coil?
Have not had a chance to look for that, I will try that tonight, and then try the multimeter with the coil / ignitor.
Had A "90 Prelude a while back that did the same exact thing.Was hard to start sometimes.....and sometimes would die while driving.Take relay out,take guts out of little box...put under magnifying glass....you"ll see hairline cracks on certain solder points....Hit them with soldering gun...problem fixed.
mailforjon
Aug 20, 2002 10:40 PM
