help car is in limp mode
Old May 17, 2004 | 06:10 PM
rkn527's Avatar
Default help car is in limp mode
i have a 93 ex civic with a 1995 gsr swap i am running the p72 but when i did the swap i didnt wire the knock sensor or the aib butterflies but i wired the aib to the ecu and a 12v source but car still doesnt drive how it is suspose to if i was to get on it hard the car would basically shut down
sry but everyone is not perfect
Modified by rkn527 at 3:23 AM 5/18/2004
Old May 17, 2004 | 06:20 PM
hatchling37's Avatar
Default Re: help car is in limp mode (rkn527)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkn527 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 93 ex civic with a 1995 gsr swap i am running the p72 but when i did the swap i didnt wire the know sensor or the aib butterflies but i wired the aib to the ecu and a 12v source but car still doesnt drive how it is suspose to</TD></TR></TABLE>
a little too vague, buddy, it's not in limp mode if the car ain't running
oh, and you might want to edit your post, seeing as how your grammar is ****
Old May 17, 2004 | 06:21 PM
Kamin's Avatar
seriously, proof read.
if it dosent make sense to you, it dosent make sense to us.
Old May 17, 2004 | 06:25 PM
rkn527's Avatar
Default Re: help car is in limp mode (Kamin)
OK PUT IT THIS WAY WHEN I GET ON THE CAR IT BOGS DOWN THEN IT GOES DOES ANY ONE KNOW WHAT COULD BE WRONG SINCE SOME H-T MEMBERS ARE ********
Old May 17, 2004 | 06:32 PM
Kangaroo_Boy's Avatar
are you throwing any codes?
Old May 17, 2004 | 06:35 PM
rkn527's Avatar
Default Re: help car is in limp mode (Kangaroo_Boy)
IT IS THROWING A CODE I KNOW BY THE KNOCK SENSOR NOT BEING CONNECTED THERE WILL BE A CODE FOR THAT BUT I TRIED TO LOOK FOR THAT LITTLE GREY HARNESS BY THE GLOVE BOX BUT NOTHING THERE IT RUNS GOOD SOMETIME BUT IT RUNS LIKE **** SOMETIMES TO. I WAS TOLD IT COULD BE THE KNOCK SENSOR SINCE IT IS NOT CONNECTED IT IS PULLING TIMING
Old May 17, 2004 | 06:47 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkn527 &raquo;</TD></TR><TR><TD CLASS="quote">IT IS THROWING A CODE I KNOW BY THE KNOCK SENSOR NOT BEING CONNECTED THERE WILL BE A CODE FOR THAT BUT I TRIED TO LOOK FOR THAT LITTLE GREY HARNESS BY THE GLOVE BOX BUT NOTHING THERE IT RUNS GOOD SOMETIME BUT IT RUNS LIKE **** SOMETIMES TO. I WAS TOLD IT COULD BE THE KNOCK SENSOR SINCE IT IS NOT CONNECTED IT IS PULLING TIMING</TD></TR></TABLE>
your caps lock is on.
and connect your knock sensor.
Old May 18, 2004 | 07:26 AM
a knock sensor code could cause the car to run in limp mode, connect that knock sensor and you should be good to go i think
Old May 18, 2004 | 07:07 PM
rkn527's Avatar
thanks to every one that could help me
NotNew
15
Aug 31, 2008 10:13 PM
evil civic
Feb 23, 2005 04:57 PM
pnltnc
Apr 11, 2004 04:41 PM
rkn527
Nov 30, 2003 06:58 PM
csan
Sep 18, 2003 10:50 PM
