whats a good quality assembly lube?
Old May 17, 2004 | 12:03 PM
spaceman's Avatar
Default whats a good quality assembly lube?
Old May 17, 2004 | 12:15 PM
wickedEFguy's Avatar
Default Re: whats a good quality assembly lube? (spaceman)
huh?
Old May 17, 2004 | 12:57 PM
spaceman's Avatar
Default Re: whats a good quality assembly lube? (wickedEFguy)
when you guys build a motor what kind of lube do you use for bearings and things like that?
Old May 17, 2004 | 03:10 PM
non-VTEC's Avatar
Permatex Ultra Slick engine assemply lube
avalable from UAP/NAPA parts stores.
http://www.permatex.com/produc...81950
Old May 17, 2004 | 03:14 PM
Ekasey's Avatar
Default Re: whats a good quality assembly lube? (non-VTEC)
would never use permatex not to knock the previous post just my opinion id use torco
Old May 17, 2004 | 03:21 PM
Tuned1's Avatar
Royal Purple
Old May 17, 2004 | 04:05 PM
Sliced Beard's Avatar
Default Re: (Tuned1)
i dunno the name of it i never pay attention to what it is called
it is that red stuff that comes in a little container shaped like a small jar of fast orange and it is sold in Auto Zone. it is like buttah i have used it on every engine i have built
Old May 19, 2004 | 05:17 AM
BB2H23A1
Guest
Posts: n/a
Default Re: (dirtyd463)
no prefrence get some sort of lube and then dump oil all over the head, put the the cams in put lube on the rockers and the cam, dump oil on them put in the full 4 quarts of oil o whatever it takes put the valve cover on and your good to go
Old May 19, 2004 | 05:29 AM
Iceman05's Avatar
moly lube
Old May 19, 2004 | 11:48 AM
kommon_sense's Avatar
Default Re: (Iceman05)
I've heard good things about the torco fluids/lubes.
http://www.torcousa.com
Old May 19, 2004 | 03:42 PM
Big Teggie's Avatar
Default Re: (kommon_sense)
I have heard good things about the Torco lubes.
I usually use Clevite Bearing Guard on bearings or the CRC stuff on other things.
Old May 19, 2004 | 05:20 PM
Bisimoto's Avatar
Default Re: (Big Teggie)
Torco...all the way!
Old May 19, 2004 | 05:38 PM
turbo96wr's Avatar
my choice royal purple never lost an engine.
Old May 19, 2004 | 08:31 PM
RABHonda's Avatar
Default Re: whats a good quality assembly lube? (turbo96wr)
Redline.
RACEPAK
Jan 28, 2011 06:21 PM
nemesis25
Jul 23, 2009 07:39 PM
nexgen91
Mar 13, 2007 01:46 PM
CivHatchH22
Feb 2, 2005 09:16 AM
eddiecut
Mar 25, 2003 07:53 PM
