leaking oil pan
Old May 16, 2004 | 11:41 AM
LAKER HATER's Avatar
Default leaking oil pan
i put on a new LS oil pan gasket last night. put some hondabond thinly on the edges of the oil on both sides of the oil pan gasket and tightened up the oil pan. now im gettin some minor leaks on the thin side of the oil pan. its not leaking bad... but theres an obvious leak, mainly on the corner. oil is getting on the flywheel. what did you do to help stop the leak? did you take off the oil pan again and re-do it? im wondering if i can do a quick fix and maybe put more hondabond on the edges without taking off the oil pan again.
Old May 16, 2004 | 02:29 PM
DC4noMore's Avatar
Default Re: leaking oil pan (affiliated)
Did you overtorque the bolts and/or did you tighten them in the correct order?
Old May 16, 2004 | 09:17 PM
PIC Performance's Avatar
Most people use a bead of hondabond around the edge AND a new gasket, afaik.
Old May 17, 2004 | 07:35 AM
nah, we didnt overtorque it. we made sure to do it in sequence. i think the hondabond wasnt evenly spread or something. its leaking like a ****. i drove it down the street and there was a puddle from start to finish. if someone followed the oil leaks, it would lead right to my driveway.
Old May 17, 2004 | 09:00 AM
conesmasher's Avatar
Default Re: (affiliated)
Hey no one is perfect, pull that before I call the EPA
Old May 17, 2004 | 09:05 AM
Default Re: (conesmasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conesmasher &raquo;</TD></TR><TR><TD CLASS="quote">Hey no one is perfect, pull that before I call the EPA</TD></TR></TABLE>
haha
yeah, i should try a "bead" of hondabond on the edges.
Old May 17, 2004 | 01:05 PM
Well do what it takes until it works, if all else fail.....use duct tape
Old May 17, 2004 | 03:03 PM
SIK IN DA HED's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conesmasher &raquo;</TD></TR><TR><TD CLASS="quote">Well do what it takes until it works, if all else fail.....use duct tape </TD></TR></TABLE>
i was thinkin about using jb weld. lol
Old May 17, 2004 | 03:30 PM
slo2kgsr's Avatar
Default Re: (SIK IN DA HED)
Some times on that end a metal ring for the two bolts on the end of the pan will stick to the block or the pan. If you didn't remove it then you bend the pan and cause a bad leak on that end. (did it last week)
Old May 18, 2004 | 07:30 AM
Default Re: (tegraLS97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegraLS97 &raquo;</TD></TR><TR><TD CLASS="quote">Some times on that end a metal ring for the two bolts on the end of the pan will stick to the block or the pan. If you didn't remove it then you bend the pan and cause a bad leak on that end. (did it last week)</TD></TR></TABLE>
metal rings? what metal rings? lol
Old May 20, 2004 | 03:27 AM
slo2kgsr's Avatar
in side the gasket there are 2 metal rings by the flywheel side of the gasket. sometimes they seperate from inside the gasket and stick to the pan or the block. Not saying it is your problem but, It happens
Old May 20, 2004 | 08:09 AM
oh ok. cool. whats a good way to take off the hondabond besides scraping, rubbing, or peeling it off. i gotta get working on it today.
Old May 20, 2004 | 04:35 PM
slo2kgsr's Avatar
scrap it off lightly sorry if the info is to late. Don't use alot of hondabond i used none and mine isn't leaking. The other techs in my shop also told me that rubber gasket arn't always helped with sealent.
Old May 21, 2004 | 07:51 AM
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegraLS97 &raquo;</TD></TR><TR><TD CLASS="quote">scrap it off lightly sorry if the info is to late. Don't use alot of hondabond i used none and mine isn't leaking. The other techs in my shop also told me that rubber gasket arn't always helped with sealent.</TD></TR></TABLE>
yeah, there are cases where the spread of hondabond offsets the flatness of the gasket creating curves in the gasket because of the uneveness.
Uljima
Jun 3, 2015 06:17 AM
uEDarkShadow
Jul 13, 2006 07:02 PM
MR. ARIZONA
Sep 3, 2003 05:04 PM
swlabhot
Aug 21, 2003 04:38 AM
Pinhead
Jun 9, 2002 01:53 PM
