89 Prelude moonroof leaking water?? HELP
Old May 16, 2004 | 11:34 AM
RacerBoy's Avatar
Default 89 Prelude moonroof leaking water?? HELP
Girlfriends 89 Lude leaks from the power moonroof area onto the passenger seat. I imagine a seal has to be replaced...which one? Anyone else experience this? Thanks for all ur help!
Old May 16, 2004 | 11:54 AM
hondainspired's Avatar
lol... havn't had the problem yet.... but... i know that when your little drain thing is clogged when you open ur sun roof you get morning shower... compressed air will solve the drain tube thing... other wise yea prob. a seal...
Old May 16, 2004 | 02:25 PM
JohnnyTequila's Avatar
Default Re: (hondainspired)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondainspired &raquo;</TD></TR><TR><TD CLASS="quote">lol... havn't had the problem yet.... but... i know that when your little drain thing is clogged when you open ur sun roof you get morning shower... compressed air will solve the drain tube thing... other wise yea prob. a seal... </TD></TR></TABLE>
yup
other end of the tube is on passenger side of the trunk
pull back the carpet, aftermoving the jack, and youll see a tube back there behind the metal between that and the filter
Old May 16, 2004 | 02:45 PM
kablamo's Avatar
Default Re: 89 Prelude moonroof leaking water?? HELP (RacerBoy)
95% certain those drain tubes are the problem.
if you have the instruction manual for the car, it actually shows where they are exactly and how you should maintain them/clean them.
anyways it's not hard to do, you just have to know where to look. blockages usually occur right where the water gets in anyways, dirt isn't likely to go through 6ft of tubing before clogging it up
Old May 17, 2004 | 05:06 PM
RacerBoy's Avatar
Default Re: 89 Prelude moonroof leaking water?? HELP (kablamo)
Cool..thanks guys i know I can always count on ya!
tekniq
Jul 8, 2008 09:54 PM
CARflyGUY
Nov 22, 2006 08:10 AM
b16pwrdeg
18
May 9, 2005 02:29 PM
Madrek
Oct 12, 2004 05:10 PM
cecknight
Sep 24, 2001 01:14 PM
