Prelude is leaking
Old Sep 22, 2001 | 08:17 AM
cecknight's Avatar
Default Prelude is leaking
I've got a 4th gen prelude and there is a leak somewhere in the trunk or rear area when it rains. Has anyone had this problem before?
Old Sep 22, 2001 | 08:18 AM
JG Luder's Avatar
Default Re: Prelude is leaking (cecknight)
try to see if your sunroof drain tube is clogged.
Old Sep 22, 2001 | 08:24 AM
cecknight's Avatar
Default Re: Prelude is leaking (JG Luder)
where is the sunroof tude? When it rains it fills up the spare tire well and when I hit the brakes, it dumps into my back seat.
Old Sep 22, 2001 | 08:32 AM
JG Luder's Avatar
that MIGHT be it. There is a drain hole at the front and back of the sunroof track. The one on the back runs down the back pillar by the rear window. I had mine clog up and it dumped water all in the back floorboard and into the trunk. KEEP THIS IN MIND:
All leaks are different.
Old Sep 22, 2001 | 08:53 AM
cecknight's Avatar
ok, how do I unclogg this? If there is a website you don't have to type it all.
Old Sep 22, 2001 | 08:55 AM
JG Luder's Avatar
damn, well, not a website that I know of. Compressed air is one way, or the way a mechanic told me is hellafied WD40 down the tube.
Old Sep 22, 2001 | 06:48 PM
prelude1897's Avatar
Same thing is happening to my car. I don't know where the **** its coming from. It pisses me off
Old Sep 23, 2001 | 07:40 PM
clockworks's Avatar
Default Re: Prelude is leaking (prelude1897)
If it's not the drain tubes, check the taillight gaskets, I've had leaks from both of those spots, though, and sunroof tubes are easier to check.
Greg
Old Sep 24, 2001 | 01:11 PM
cecknight's Avatar
Default Re: Prelude is leaking (clockworks)
well, I think I fixed it. The tube ends are found in the trunk right next to the tire wells. I had to take the lining of my trunk out. The tube ends are clamped to a naros opening which doesn't let dirt out so it plugs up. I trimed them to there was a bigger opening so if anymore dirt goes down it'll dump it. Thanks, JG, for the idea.
Old Sep 24, 2001 | 01:14 PM
JG Luder's Avatar
hey, I just hope it works! Don't thank me, thank my Honda God Mechanic Don for teaching me these little tricks. hahahaha.
hennessy
Aug 23, 2009 05:37 PM
JaysenF135
Feb 1, 2006 09:06 AM
RacerBoy
May 17, 2004 05:06 PM
bdb
Oct 16, 2003 12:56 PM
BoostedH23a1
Sep 17, 2002 06:22 AM
