Leaking and floor boards are puddles.
Ok last rain fall I had puddles in both my driver side and passenger side floor boards..People say I have a leaking windshield cowl. I took off all the pins and everything and tomorrow I will silicon everything up...Anyone have this problem and did sealing the cowl with silicon work? Can it be something else that is causeing a bad leak into my floor boards? Help me out and let me know if anyone experienced this problem before.. Thanks
Re: Leaking and floor boards are puddles. (Madrek)
Known problem for some Civics. Use a search engine (Google etc) on the topic. Check the firewall ....air plenum. Leaks can be hard to pinpoint because often water only moves in when you are at speed...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Madrek »</TD></TR><TR><TD CLASS="quote">Ok last rain fall I had puddles in both my driver side and passenger side floor boards..People say I have a leaking windshield cowl. I took off all the pins and everything and tomorrow I will silicon everything up...Anyone have this problem and did sealing the cowl with silicon work? Can it be something else that is causeing a bad leak into my floor boards? Help me out and let me know if anyone experienced this problem before.. Thanks</TD></TR></TABLE>
the same sh*t happened to my old DA . . . the seal between the cowl and the windshield was worn out.
