Testing a DEI rattler 369D
So i'm installing a rattler 369D on my brothers integra. I get alll the way to the end, minus the clutch bypass. Everything works, including the RS(assuming i step on the clutch). I go inside to solder a relay for the clutch bypass leaving everything plugged in. When i come out nothings working, the status LED doesn't responde to the programming switch. I check all the power wires with a DMM and everything is still soldered and connected. So my only question is this, how do i know if i blew the unit? can i take it to a DEI dealer and have them test it? would there be any fuses associated with the unit working. As far as i can tell the unit is getting power but for some reason its not responding to the remote / programming switch. Thanks in advanced
-kenny
-kenny
When my alarm stopped working.. i took the brain out.. and snifffed it like a dog.. it had this funky smell.. im not sure how to describe it. but it was the smell of sum stuff that burned up..
CrazyModGSR
Audio / Security / Video
Oct 30, 2004 10:36 PM
Bklyn TSi
Dec 29, 2001 02:36 PM
369d, alarm, brain, bypass, dei, install, instructions, manual, model, programming, rattler, remote, reprogramming, review, start
