Testing a DEI rattler 369D
Old May 15, 2004 | 07:49 PM
Trixiem's Avatar
Default Testing a DEI rattler 369D
So i'm installing a rattler 369D on my brothers integra. I get alll the way to the end, minus the clutch bypass. Everything works, including the RS(assuming i step on the clutch). I go inside to solder a relay for the clutch bypass leaving everything plugged in. When i come out nothings working, the status LED doesn't responde to the programming switch. I check all the power wires with a DMM and everything is still soldered and connected. So my only question is this, how do i know if i blew the unit? can i take it to a DEI dealer and have them test it? would there be any fuses associated with the unit working. As far as i can tell the unit is getting power but for some reason its not responding to the remote / programming switch. Thanks in advanced
-kenny
Old May 16, 2004 | 12:59 PM
john666's Avatar
Default Re: Testing a DEI rattler 369D (Trixiem)
When my alarm stopped working.. i took the brain out.. and snifffed it like a dog.. it had this funky smell.. im not sure how to describe it. but it was the smell of sum stuff that burned up..
Old May 17, 2004 | 03:32 PM
Trixiem's Avatar
Default Re: Testing a DEI rattler 369D (john666)
haha i know what you mean, but i took this brain apart and there ws no signs of burns or even shorts.
-kenny
Old May 17, 2004 | 05:04 PM
rjr162's Avatar
you can always just give it +12 and ground out of the car and test every output with a multi-meter
hondaspeed305
Audio / Security / Video
Nov 25, 2008 11:22 AM
jonahd
May 4, 2008 09:41 AM
CrazyModGSR
Oct 30, 2004 10:36 PM
Odessa
Aug 18, 2004 07:37 AM
Bklyn TSi
Dec 29, 2001 02:36 PM
