Is the ITR engine a direct bolt in for ek?
I am buying an itr engine for my ek, well, actually ej hatch. Is this pretty much a direct bolt in? If this isn't the right place to post this, forgive me, I figured someone with an itr might know. What will I need to make it work. Any help is appreciated!
Modified by 97mini-me at 8:33 PM 5/15/2004
I've searched under everything I can think of. I haven't found anything. I wouldn't post unless I've searched. I know there are people that do, but I'm not one of them. I really need to know this. Ordering engine on monday, putting it in in like 2-3 weeks. I want to have all the parts readily available so I can drop and go. If there are any other parts you can think of that I will need, let me know. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97mini-me »</TD></TR><TR><TD CLASS="quote">I am buying an itr engine for my ek, well, actually ej hatch. Is this pretty much a direct bolt in?
Almost, you'll need a few parts from a 99 Si. Like left-hand engine bracket, rear bracket. You'll also need the front transmission bracket if your engine doesn't have one and an AC bracket but I forget what year.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian g »</TD></TR><TR><TD CLASS="quote">an AC bracket but I forget what year.</TD></TR></TABLE>
A Del Sol DOHC VTEC (P54) a/c mount and he will have to reuse his sohc a/c compressor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">
A Del Sol DOHC VTEC (P54) a/c mount and he will have to reuse his sohc a/c compressor</TD></TR></TABLE>
Yeah, but they're different 94-95 and 96-97. Which year is it?
brian g
brian g
I´m looking into the same subject and this cleared a lot for me.
http://www.phear7imports.net/s...6gen/
I have understood everything ecxept the secondary 02 sensor.
Does that mean that there is a second 02 sensor on the exhaust after the the cat?
and also the thing whit the drivers side mount. In the site above he says you have to buy an drivers side mount from civic si 99-00 but here it says that you uses your old civic mount?
http://hybrid2.honda-perf.org/tech/6gmatt.html
brian g</TD></TR></TABLE>
I have always used OBD1 (94-95 with no problem but I have had people use 96-97 with no problems) (i do not have first experience with 96-97)
I have also used CRV a/c mount and it is the same (most are marked P54 and some are P30)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kivi85 »</TD></TR><TR><TD CLASS="quote">I´m looking into the same subject and this cleared a lot for me.
http://hybrid2.honda-perf.org/tech/6gmatt.html</TD></TR></TABLE>
Yes there is an second O2 sensor but it's in the cat. Unless it's a JDM ITR, then there's no secondary O2
It's the driver-side bracket not mount.
brian g
brian g
That article helped me out alot! Thanks man. So I need a couple of mounts, and since I have the ex wire harness all I will have to do is extend a few wires and I should be alright? Thanks again. If anyone has anything else, POST!
EDIT: Nevermind, it is in the post above. (Kicking self in ***)
Modified by 97mini-me at 7:35 PM 6/2/2004
{Powered by VIII}
Mar 19, 2004 01:00 AM
