will itr lca's fit an ek?
Old Feb 13, 2004 | 11:39 PM
SoCaLNaTIvE's Avatar
Default will itr lca's fit an ek?
i have 5lug on my dc, and nice suspension. if i buy an ek will every thing change over? can i run itr lca's which will allow me to keep my current suspension?
Old Feb 14, 2004 | 12:26 AM
92b16vx's Avatar
Yes
Old Feb 14, 2004 | 12:49 AM
Katman's Avatar
Default Re: (92b16vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx &raquo;</TD></TR><TR><TD CLASS="quote">Yes </TD></TR></TABLE>
NO NO NO!!!!!!
ITR rear LCA's will NOT work on an EK (nor will the fronts). The rears are too short in length and the front LCA's are of different geometry. You have to stick with EK front upper A-arms * LCA's + rear LCA's when converting to 5-lug. The ITR front knuckle+brake assembly and rear trailing arms will bolt up to an EK chassis as long as you keep the EK parts I just mentioned....
Old Feb 14, 2004 | 02:09 AM
92b16vx's Avatar
Default Re: (Katman)
Really? I thought as long as you used all the ITR parts it would fit?
Old Feb 17, 2004 | 10:44 PM
jdmexsi's Avatar
I will definately agree with Katman
Old Feb 18, 2004 | 01:27 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (jdmexsi)
no , they 100% for sure do NOT fit on the ek , they do NOT!!!!!!!!!!!
Old Feb 18, 2004 | 07:40 AM
SpeedyEk9's Avatar
Default Re: (Hella_JDM)
The LCA will not fit
I have a DC2 R 5 lug conversion on my EK
the DC2 LCA's were about two inches too short on each side
and i used 99 SI rear LCA so that i could use a ITR sway bar
hope that helps confirm what was said above
Dave_yd
Suspension & Brakes
Nov 1, 2008 01:07 PM
lDanny
13
Jun 10, 2004 02:00 PM
{Powered by VIII}
Mar 19, 2004 01:00 AM
EKen9
Apr 18, 2003 09:39 PM
Blown90hatcH
14
Apr 6, 2002 12:17 AM
