Inline walbro, now have code 16
Old May 14, 2004 | 07:00 PM
StupidSlowRSX's Avatar
Default Inline walbro, now have code 16
DOHC ZC with inline walbro 255. CEL 16, im not suprised... I hear that its common amoung crxs w/ inline pumps. However, my crx can rev past 4k, and Im still throwing a code 16.
Old May 14, 2004 | 07:10 PM
y49crxsi's Avatar
Default Re: Inline walbro, now have code 16 (StupidSlowCRX)
Hmm, ussually got that code when i was running to rich or something, it never was my injectors, i think that code is universal, lol. Maybe the walbro is just giving to much pressure, and teh fpr cant handle it, get a fp guage and see what its at.
Oh, and does it run like crap? What happened to limp mode, find the problem???
Old May 15, 2004 | 02:45 AM
eh, limp mode is fixed, i jus rewired crank angle. I already have a FP gauge, and regulator. gauge is set perfect, however, it bounces, its at about 37 psi at idle, but it bounces from 34-37. I figure its because the pump drips slowly since its made for intake. I guess ill just half to put it back int he tank -,-
btw, it runs fine.
Old May 15, 2004 | 08:48 AM
crx_88_si's Avatar
Default Re: (StupidSlowCRX)
full warm idle fuel psi should be 30ish.
Old May 15, 2004 | 02:20 PM
Default Re: (crx_88_si)
??? OEM Honda recommends 35-41 psi.. I have all the bolts on. so im at 40
Old May 15, 2004 | 04:42 PM
sohcfreak's Avatar
why dont you reset the ecu code..?
after that check your connections in the fuel pump area.. i had that same problem and i was messing around with the wires and reset my ecu and ...bam no code...
Old May 15, 2004 | 05:11 PM
oh ya,
whats an ECU? -,-
been there done that. Thanks
xlusiveracer
Honda CR-V & Element
Jan 6, 2017 05:54 AM
shawn69
Engine Management and Tuning
Aug 16, 2009 10:01 AM
JhorickJFL
Aug 27, 2004 12:34 AM
Turbohatch
Sep 10, 2001 08:38 AM
newt2
Jul 6, 2001 07:58 AM
