OBD2 to OBD1
I have a 96 ls engine and I need to convert it into a OBD1- will this work for a harness?
http://cgi.ebay.com/ebaymotors...=WDVW
It works just fine. I have a 1995 gsr motor in my 1997 ls. Use the obd1 ecu, you'll need a obd2<obd1 conversion harness. You'll also need to wire vtec, knock sensor, and the secondaries for the im. FYI: it's illegal to have an obd1 motor in an obd2 car. If you plan on passing emissions you'll need to add a ckf sensor, which requires a obd2 oil pump and the senor itself, as well as an obd2 ecu of course.
Now I see your problem, it wasn't very clear in the first question. You'll need to run an obd1 ecu for it to work, becuase i don't think they make obd1>obd2 conversion harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jentegraGS-R »</TD></TR><TR><TD CLASS="quote">i think the obd2 harnesses for a 2000 gsr are different than the 96-99. </TD></TR></TABLE>
DING DING DING yes you are correct sir...there are obdIIA and OBDIIB wich requires differnt harnest.
its 96-99 and 00-01
its 96-99 and 00-01
screen_name
Apr 22, 2006 06:56 PM
