cam question
Old May 14, 2004 | 08:50 AM
sihatchyvtec's Avatar
Default cam question
i have a p72 ecu where the vtec kicks in at 4500 on my gsr,, is it worth buying itr or ctr cams w/ that low of vtec engagement? this is w/ stock gsr intake manifold also.. thanx let me no
Old May 14, 2004 | 09:59 AM
devnull's Avatar
regaurdless of where VTEC kicks in it would help you.
It sounds like you have the ECU chiped. May I suggest you change the chip to that of one that has a higher VTEC engagement (5500)
Old May 14, 2004 | 10:28 AM
Ekasey's Avatar
Default Re: (qi_doy)
yeah usually 5500 is about where vetc engagment works best, and yes itr/ctr cams are a great upgrade regardless and a great cam for a mild street application
Old May 14, 2004 | 10:32 AM
wickedEFguy's Avatar
Default Re: cam question (sihatchyvtec)
DAMM 4500 is pretty early
Just like everyone else says CTR\ITR is a great upgrade for your stock valvetrain
Old May 14, 2004 | 03:57 PM
Katman's Avatar
4500-4800rpm is normal for a stock P72 GSR ecu, because of the secondary butterfly duties. I suggest you stick with the P72 ecu if you drop in any type-R cams, otherwise you'll lose low-end torque if you bump VTEC up too high.
Sub|ime
Sep 28, 2010 02:34 AM
tekstyle
Mar 13, 2008 04:01 PM
Ruthless671
Aug 15, 2005 03:07 PM
IGotVTECyo
Jun 24, 2005 03:44 AM
cliff666
Feb 18, 2005 06:20 AM
