REMOVING DIZZY
Old May 14, 2004 | 04:14 AM
Layziebtnh055's Avatar
Default REMOVING DIZZY
the bolts are on really tight and i just keep stripping the bolt,
Old May 14, 2004 | 04:22 AM
RobbieG35's Avatar
12 Years Strong
Default Re: REMOVING DIZZY (Layziebtnh055)
Try a pair of vice grips, if the bolt is that close to stripped you may as well try that. It will destroy the bolt, but it will be fucked anyway if its stripped
Old May 14, 2004 | 04:30 AM
1st-hybrid's Avatar
Default Re: REMOVING DIZZY (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">Try a pair of vice grips, if the bolt is that close to stripped you may as well try that. It will destroy the bolt, but it will be fucked anyway if its stripped</TD></TR></TABLE>
I say vise grips as well, however this is a common misconception, that vice grips will "destroy the bolt". When used properly vice grips are a very versatile tool that can get you out of a pinch.
Old May 14, 2004 | 06:42 AM
manson's Avatar
Default Re: REMOVING DIZZY (1st-hybrid)
you sure have a hard time using tools... 2 posts about stripping bolts...
use the correct tool for the job and you won't have problems.
try the vice grips, but be careful.
spidermancivic
Aug 11, 2007 08:17 AM
EFstyle
23
Jan 27, 2007 10:49 PM
civicEXtreme
Suspension & Brakes
Feb 22, 2006 02:36 PM
Mikey
Apr 25, 2003 08:47 PM
Allstar
Nov 11, 2002 11:14 PM
