DO I NEED TO SWAP TRANNY FOR AN LSD ON MY 00 SI CIVIC
Old May 13, 2004 | 08:26 AM
flyrice's Avatar
Default DO I NEED TO SWAP TRANNY FOR AN LSD ON MY 00 SI CIVIC
hey guys, do i need to swap the tranny for an lsd to be install or i can install it on my 00 si, thanks in advance
Old May 13, 2004 | 08:56 AM
fearless_dsm's Avatar
Default Re: DO I NEED TO SWAP TRANNY FOR AN LSD ON MY 00 SI CIVIC (flyrice)
you can install a lsd in your tranny.An integra type r LSD fits in with no modifications.Ive gpt one for sale,im me if youre interested.
Old May 13, 2004 | 09:08 AM
Dan GSR's Avatar
Default Re: DO I NEED TO SWAP TRANNY FOR AN LSD ON MY 00 SI CIVIC (fearless_dsm)
you will also need a itr ring gear
Old May 13, 2004 | 09:29 AM
T.J.'s Avatar
no need at all for a new tranny.
Old May 13, 2004 | 10:26 AM
Default Re: DO I NEED TO SWAP TRANNY FOR AN LSD ON MY 00 SI CIVIC (Dan GSR)
You dont need the ITR ring gear..the usdm ITR FD/ring gear is the same as the 99-00 si.The JDM ITR FD is 4.7,to use that you need the JDM ITR pinion shaft too.
Old May 13, 2004 | 11:53 AM
Dan GSR's Avatar
the si and itr have the same ratio of 4.4
but the ring gear itself is not the same
the inner diameter of each one is different
impossible to fit an si ring gear on a itr diff
Old May 13, 2004 | 12:22 PM
shivers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fearless_dsm &raquo;</TD></TR><TR><TD CLASS="quote">You dont need the ITR ring gear..the usdm ITR FD/ring gear is the same as the 99-00 si.</TD></TR></TABLE>
Not the same. Internal diameter of the Si ring gear is 4.25" while the internal diameter of the GSR/ITR ring gear is 4.5" ... Big Teggie had pics up not too long ago to show the difference in the ring gears.
Old May 13, 2004 | 01:11 PM
Default Re: DO I NEED TO SWAP TRANNY FOR AN LSD ON MY 00 SI CIVIC (shivers)
ive got an ITR diff. in my 93 gsr tranny w/the 93 gsr ring gear,so i figured it was the same.sorry.
Rishiras
Jul 26, 2005 08:07 PM
JdmTypeR202
Jun 22, 2004 10:56 AM
justBLZE
Apr 3, 2004 06:41 AM
bearboy80
28
Sep 9, 2003 09:01 PM
getgot2
Jun 10, 2003 08:19 PM
