ITR LSD in my 99 SI is not fitting!?!
Old 06-10-2003, 03:40 PM
getgot2's Avatar
Default ITR LSD in my 99 SI is not fitting!?!
I tried to put the ITR lsd in my 99 SI and the ring gear doesnt match the chunk(lsd). It isn't big enough for the lsd. Do I juss get the USDM ITR final gear or, do I have to get the countershaft as well?
Help me! I need to know, I dont have a car....
Old 06-10-2003, 03:43 PM
big strong guy
rainmanEK's Avatar
Default Re: ITR LSD in my 99 SI is not fitting!?! (getgot2)
ITR LSD will not fit!
If i remeber correctly, The B16a Diff is Actually Smaller then 1.8 liter diffs
Eric
Old 06-10-2003, 03:52 PM
1 2 NV's Avatar
Default Re: ITR LSD in my 99 SI is not fitting!?! (rainmanEK)
actually the B16 and LS share the same size diffs. the ITR and GSR have the bigger ones.
Old 06-10-2003, 03:55 PM
RichardCranium's Avatar
OT: No Control Owns...
Old 06-10-2003, 03:56 PM
getgot2's Avatar
Default Re: ITR LSD in my 99 SI is not fitting!?! (hondaatwsu)
so do i have to replace the ring gear and countershaft, or juss the ring gear?
Old 06-10-2003, 03:57 PM
1 2 NV's Avatar
should just have to swap in the ring gear. ITR and SI trannies have identical gear sets 1-5.
Old 06-10-2003, 04:00 PM
getgot2's Avatar
i hope this works cause if not i have a itr diff that i cant use, and a car that is not running due to broke spiders..
Old 06-10-2003, 08:19 PM
JurakS's Avatar
I put an itr lsd into my civic si too, all you need to use is the gsr or type r ring gear.
harta_tec
06-20-2008 11:17 AM
known
06-10-2006 09:41 AM
Quick Reply: ITR LSD in my 99 SI is not fitting!?!
