Steady CEL Light..p72 into vx (h22 eg)
Location: In the heart of the ghetto of the, Suburbs NYC
What or why would this happen if i jumped the connector correctly? I can't figure out my cels after the swap, cause the engine light doesn't flash...help!!!!
tell me about it..i thought i was jumping it incorrectly also, becuase there is two connectors there on the vx, but i tried both and jumped both, but no flashes to my avail
Re: (92hybridAccord)
Usually if you dont get a code and the car is only revving to 3k that means you have a bad epprom on the ECU and you may have to get it checked. Juss slap on a p28 or p13 and see what happens then..
Is it finally running dawgs?!
Re: (Jason kiDD)
yeah man...running now, just working out the issues as i go along...will take pics and update soon enough.
The car is idling just at about 900-1100 but i can't figure out why i have a steady cel..don't have another p13 or p28 to check out..searching for one
Well that is good. But again that usually means a bad ECU.. I have my ole p13 here if you are really desperate to try something out.. You can use stock Accord Ecus as well juss no vtec.
