Bad Valve Guides, seals, bent valves??? HELP Searched
what one of these would cause tons of smoke to come out my exhaust at all rpm, i kno its oil burning and my oil smells like gas
oil smells like gas wouldnt be valve guides as the two never really come in contact. I fear your rings are shot. do a compression test.
sounds like your ignition is done....try going through your spark plugs, wires, cap & rotor.......
fixed a car last week that had the problem you describe with new wires...
good luck
edit: what kind of motor???....check your vacuum lines too
good luck
What are the regular symptoms of a bent valve. My friends car may have the same problem. First of all the shaking of the engine which causes the car and exhaust to shake (maybe bad motor mount? but i doubt that), it pulls fine durin normal driving and redline that i felt when i drove it, but he tried to pull some codes and i think something is wrong with cylinder 2 and 3 i think? What do you guys think? Bent valves possible ignition problem?
