Honda S2000 Honda S2000
Smoking
Old Nov 3, 2007 | 04:01 PM
S2SLOW's Avatar
Default Smoking
My problem is the car smokes at idle at Random times... You can drive for an hour and never see it smoke and then while at a stoplight it will smoke for 5-10 seconds.. And its definitely oil smoke not gas...
Im puzzled to what it is, maybe valve seals I dont know. Compression #s are very high...It's a 2002 with 97,xxx miles on it....
Any help on this would be much appreciated... Thanks chris
Old Nov 3, 2007 | 04:56 PM
JDM knowledge's Avatar
Default Re: Smoking (S2SLOW)
i dont smoke its bad for your health.
But umm sounds like early valve seal warning to me. Try a leakdown test. What are the compression numbers exactly???
Old Nov 3, 2007 | 05:30 PM
S2SLOW's Avatar
Default Re: Smoking (JDM knowledge)
227-228 on all 4
Old Nov 3, 2007 | 10:06 PM
s2kdre's Avatar
my friend had the same problem, compression was good, and it only smoked on start up and idle, it was the valve guides and seals.
Old Nov 3, 2007 | 10:28 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2SLOW &raquo;</TD></TR><TR><TD CLASS="quote">227-228 on all 4</TD></TR></TABLE>
how many cranks?
fuel pump is off?
Old Nov 4, 2007 | 05:17 AM
S2SLOW's Avatar
Default Re: Smoking (iam7head)
2-3 cranks fuel was on didnt pull the relay, but they were all within 1-2 psi of each other so thats not the problem....It just smokes like every other day not all the time. It could be guides and seals but i dont know....
Old Nov 4, 2007 | 10:05 AM
Default Re: Smoking (s2kdre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kdre &raquo;</TD></TR><TR><TD CLASS="quote">my friend had the same problem, compression was good, and it only smoked on start up and idle, it was the valve guides and seals.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2SLOW &raquo;</TD></TR><TR><TD CLASS="quote">2-3 cranks fuel was on didnt pull the relay, but they were all within 1-2 psi of each other so thats not the problem....It just smokes like every other day not all the time. It could be guides and seals but i dont know.... </TD></TR></TABLE>
Old Nov 4, 2007 | 10:26 AM
llxzxll's Avatar
my 2002 with 29,000 miles does the same thing. i've noticed my MPG has gone down considerably too. is the valve seal thing a big deal? expensive to fix?
Old Nov 4, 2007 | 10:34 AM
Francesco's Avatar
rings maybe?
Old Nov 4, 2007 | 10:48 AM
S2SLOW's Avatar
Default Re: Smoking (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">rings maybe?</TD></TR></TABLE>
Oil rings going bad it would do it all the time....
Old Nov 4, 2007 | 08:27 PM
bky's Avatar
bky
Oil rings going bad it would do it all the time....</TD></TR></TABLE>
Under load, yes.
Bad rings would also show up in the compression tests.
Old Nov 5, 2007 | 05:54 AM
S2SLOW's Avatar
Default Re: Smoking (bky)
Thanks for all the help guys...
Old Nov 6, 2007 | 08:48 AM
fred92htch's Avatar
Mine smoked a little when I stopped at red lights and I used about a quart of oil every 3-5k miles. I bought some crank vents and it totally stopped both the oil burning and using.
https://honda-tech.com/zerothread?id=2069580
Redprelude98
30
Jul 21, 2009 01:21 PM
Triblade
Feb 21, 2006 06:15 PM
turbo95eg6
Jul 10, 2005 07:22 AM
ALLMOTOR18
Dec 27, 2003 07:54 AM
GOTNOS
Apr 16, 2003 04:37 PM
