d16z6 wont start
Old May 13, 2004 | 12:52 AM
mikehawkBUiLT's Avatar
Default d16z6 wont start
recently, my car hasn't been starting, strictly in the morning. i also noticed it was cold outside everytime it didn't start. when i turn the key, it doesn't crank or anything, no sounds coming from my car at all. what could be the problem? bad timing? starter? thanks
Old May 13, 2004 | 12:54 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: d16z6 wont start (EJcoupe)
sounds like a bad battery.
Old May 13, 2004 | 01:01 AM
it starts fine during the day
Old May 13, 2004 | 01:39 PM
bump
Old May 13, 2004 | 01:46 PM
trooper0641's Avatar
Default Re: (EJcoupe)
maybe your alarm is on :D
Old May 13, 2004 | 01:56 PM
umm, nah...cmon guys, i need some help here
Old May 13, 2004 | 02:02 PM
life sux die's Avatar
RIP 1032
i'v was having the same problem. every morning i'd crank and crank and nothing. turns out it was my starter. take it to autozone or something. i hear they will check all your electrical stuff for free.
Old May 13, 2004 | 02:04 PM
mantic6t9's Avatar
Default Re: (life sux die)
You may also want to check your main relay.. I had this problem in my si hatch. It costs $50-60 to replace.
Old May 13, 2004 | 03:14 PM
but it doesn't crank at all. its like the battery is dead, but if i wait til the afternoon when it gets warm, my car will start fine
Old May 13, 2004 | 03:28 PM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe &raquo;</TD></TR><TR><TD CLASS="quote">recently, my car hasn't been starting</TD></TR></TABLE>
you kinow what this means. time for a swap
Old May 13, 2004 | 03:37 PM
no help...
Old May 13, 2004 | 10:42 PM
Old May 13, 2004 | 10:55 PM
Ignitecivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mantic6t9 &raquo;</TD></TR><TR><TD CLASS="quote">You may also want to check your main relay.. I had this problem in my si hatch. It costs $50-60 to replace. </TD></TR></TABLE>
or try to check ur starter.
Old May 13, 2004 | 11:32 PM
peiku's Avatar
well it might be that your ground wires are a little bit worn down. check to see if they need to be replaced.
Old May 14, 2004 | 09:56 AM
Default Re: (peiku)
nope, its not the ground wires. bump cause it happened again this morning
Old May 14, 2004 | 11:21 AM
chronodyne28's Avatar
It's either the battery or the alternator that's draining the battery.
Old May 14, 2004 | 11:53 AM
my mechanic says it has to be the starter, can anyone confirm this?
Old May 14, 2004 | 11:59 AM
Turbogixxer's Avatar
it is probably your starter and or your battery
you have to test them
Old May 14, 2004 | 12:31 PM
how much does a starter for a d16z6 go for?
Old May 14, 2004 | 07:57 PM
bump for friday night
Old May 15, 2004 | 10:39 AM
TTT
Old May 15, 2004 | 12:29 PM
handa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe &raquo;</TD></TR><TR><TD CLASS="quote">how much does a starter for a d16z6 go for?</TD></TR></TABLE>
i'd say around $50 brand new. you can get them for alot cheaper.
Old May 15, 2004 | 01:28 PM
E-brake or Handbrake's Avatar
Default Re: (handa)
I'm almost 99% sure that it's your starter. If you've got 15-30 minutes, you could yank it out & test it at Autozone as mentioned above. 2 bolts, 2 wires and out it goes.
Is your fuel pump priming? Do you hear it when you turn your key in the "ON" position? One way to listen is to look for the CEL to come on and off. Let us know
Old May 15, 2004 | 01:30 PM
Simple's Avatar
Default Re: (Inconclusive)
are you pushing the clutch down all the way? my car started doing that, id have to push it ALL the way to the floor before it will start now...
as far as in the mornings, is your ECU chipped? could be that the fuel left over in the cyl needs to clear out before it'll start
Old May 15, 2004 | 05:36 PM
^^ actually, its weird because, you dont even have to push the clutch to start my car but i do anyway, and yes i push it all the way down.
ill get my starter checked on monday. and ill let you guys know
silez
May 1, 2014 03:55 AM
EFS463
Aug 14, 2013 05:10 PM
lilo_goki
Nov 11, 2008 08:03 PM
ck123
Jun 16, 2006 09:58 PM
