CAR WONT START
Old May 12, 2004 | 01:09 PM
neogenesis2004's Avatar
Default CAR WONT START
ok ok, heres the situation. My car will turn over.....and over and over. So i know the starter is fine. Heres the kicker though, im not getting any spark. The plugs are brand new so its not them either. How do i know or test the wires? How do i know and test the distributor? I cant afford to replace everything right now, so i need to know what to look for to see if its bad. Or if you might know of it being somethin g else than by all means share your story. Oh, and yes i am getting fuel, you can smell it after pull the plugs after a few cranks.
Old May 12, 2004 | 02:27 PM
Ekasey's Avatar
Default Re: CAR WONT START (neogenesis2004)
check the grounds right baove the thermostat there too circular clips integrated into the harness that bolt to the top of the thermostat housing, worst case try swapping the dizzy with a friends
Keno20
Jan 26, 2009 10:10 PM
CuteAccord
37
Jan 3, 2009 10:41 AM
iceman7329
Jul 12, 2007 11:12 AM
curiousgpnoy
Jan 26, 2003 02:12 PM
