NEED HELP ASAP Crank Cap ??????
Old May 12, 2004 | 11:20 AM
Dammit_Dan_954's Avatar
Default NEED HELP ASAP Crank Cap ??????
I have a gs-r bottom that is being sleeved. The machine shop told me that 2 of my crank caps have cracks in them and they are no good. I heard it is not good to mix and match caps. Can someone please let me know what can be done to save this block and not let it go to the dumpster?
I also found a whole set of used crank caps for a gs-r can they be used? Comes with all of them.
Old May 12, 2004 | 02:31 PM
Ekasey's Avatar
Default Re: NEED HELP ASAP Crank Cap ?????? (FastAssEG)
You can use caps from another block but then your block needs to be align honed/bored by the machine shop so the main bore alignment is straight and all correct the ahrd part is then your gonna ahve too measure all your clearances out and carefully selct the right bearing too match those clearances
Killaogbobby
Mid-Atlantic (Sales)
Jan 7, 2010 06:52 PM
Combustion Contraption
Aug 14, 2006 05:29 PM
masterk0ns
Sep 15, 2002 04:35 PM
