How to remove crankshaft pulley?.......
Old May 12, 2004 | 07:38 AM
originalbadbob's Avatar
Default How to remove crankshaft pulley?.......
Hello, First I would like to thank those that helped with the Flywheel question I really appreciate it.
Now, what is the proper why to remove the pulley from the crankshaft?......
I am new to Hondas , but if anyone needs help with an older Mustang please let me know........Thanks again, Bob
Old May 12, 2004 | 07:47 AM
manson's Avatar
Default Re: How to remove crankshaft pulley?....... (originalbadbob)
HUGE BREAKER BAR!
or a very powerful impact gun.
im sure you won't get it off anyother way.
Old May 12, 2004 | 08:58 AM
Default Re: How to remove crankshaft pulley?....... (mansonclubpuir)
Ok, but how do you keep the pulley from turning?
Old May 12, 2004 | 09:29 AM
crx_88_si's Avatar
alot of people hold the crank in place by wedging the flywheel with something
Old May 12, 2004 | 10:03 AM
APEX CRX's Avatar
If its a factory pulley, there are special tools you can get form either the dealer or like from Moroso
Old May 12, 2004 | 10:17 AM
c for sea's Avatar
I took mine off by removing the oil pan, then wedging the handle (wood) side of a hammer between the crankshaft, then proceeded to take the pulley off. you can use a breaker bar or air gun to remove the pulley with ease. the handle should be thick enough and it'll eliminate the pulley from turning.
Old May 12, 2004 | 10:31 AM
Malgerus's Avatar
Default Re: How to remove crankshaft pulley?....... (c for sea)
Or you can just put it in 4th gear and have someone stand on the brakes.
Old May 12, 2004 | 10:40 AM
Rywire's Avatar
Default Re: How to remove crankshaft pulley?....... (Mr. S)
Why 4th gear? just wondering, thanks, Ryan
Old May 12, 2004 | 10:41 AM
mmoto68's Avatar
I took a 3/8" by 2" by 2' bar. Drilled two holes that line up w/ the pulley.
2 - 2" long bolts/nuts
2' breaker bar w/impact socket (broke 2 craftsmans attempting this). Also do not use an extension
Jack up front end
Disconnect the motor mount to drop the motor down
Hold the bumper w/hands
Put foot on breaker bar
Pop the sucker off
I tried all kinds of ways to brace the pulley from turning. I bent/broke a couple of grade 8 bolts trying to get it off with extensions/ bracing the pulley with screwdrivers/crowbars, etc.
Old May 12, 2004 | 10:42 AM
Malgerus's Avatar
Default Re: How to remove crankshaft pulley?....... (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Why 4th gear? just wondering, thanks, Ryan</TD></TR></TABLE>
Hmm not sure. Everyone has just always said to put it in the higher gears when you do it.
Old May 12, 2004 | 10:50 AM
Rywire's Avatar
Got ya, thanks
Old May 12, 2004 | 10:54 AM
krazyDOHC's Avatar
I never had any luck having someone step on the brake pedal and putting it in gear.
This is what I usually do...take the fywheel cover off ...find a small bolt that will go into to flywheel holes, and bolt on one of the bolts for the flywheel cover on to the tranny without the cover.....then stick an open end wrench in between the 2 bolts and rotate the crank till they hit eachother...jack the car up and use a big *** breaker bar
good luck
Old May 27, 2004 | 09:26 AM
B1TEM3's Avatar
Default Re: How to remove crankshaft pulley?....... (krazySOHC)
My water pump shaft is failling, timing belt hitting the cover when the engine is on.
(wobble water pump gear). Planning to replace timing belt & water pump.
I need to get that sucker off too.
I have 1/2" torque wrench i could use for breaker bar and 17 mm socket.
but it keeps turning too...
Old May 27, 2004 | 10:29 AM
Mr_CRX's Avatar
Default Re: How to remove crankshaft pulley?....... (B1TEM3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B1TEM3 &raquo;</TD></TR><TR><TD CLASS="quote">I have 1/2" torque wrench i could use for breaker bar and 17 mm socket.
don't use a torque wrench as a breaker bar. Get the right tool for the job.
Old May 27, 2004 | 10:33 AM
crx_88_si's Avatar
Honda tunin mag has a segment on changing the Timing belt. they said you can also wedge something in the flywheel where the starter bolts up. (have to take the starter off)
Old May 27, 2004 | 12:24 PM
I am the guy with the original post. I looked around for the tool which I thought after finding it was a bit expensive for what it was.
So..... I got a piece of 1/4" x 2" x 24" steel drilled a couple holes in it bolted two 4" bolts in it and it works great for holding the pulley when you are taking off the nut ( or putting it back in) also great when you are needing to remove the fly wheel.
If you like I could email you a picture ? of the tool.
Thanks , Bob
Old May 27, 2004 | 12:28 PM
civickiller's Avatar
put a impact to it, shoudl come free, if not just keep turning up the pressure
Old May 27, 2004 | 12:34 PM
crx_88_si's Avatar
Default Re: How to remove crankshaft pulley?....... (civickiller)
not every1 has air tools.
Xscort
Jul 25, 2008 10:54 PM
budomove
Nov 2, 2007 07:26 AM
coreyhayman
57
Oct 5, 2006 11:44 PM
djnikko
19
Apr 24, 2005 07:43 PM
94vtecmn
Apr 21, 2003 12:08 PM
