Turbo help !!!!!!!!!!!!!!!!!
Old May 12, 2004 | 06:08 AM
jonbouy's Avatar
Default Turbo help !!!!!!!!!!!!!!!!!
hi everyone iam from the uk i have a honda civic ek6 1.5vtec. The engine number is d15z6 its 115bhp stock 72000miles. i dont think this engine is availble in the usa its just for europe. i was wondering what turbo would be best to use, would the engine still be very relieable in its stock form with a turbo on it or would i have to make some big changes. also is this a good engine to be doing it on thanks for any help jon uk
Old May 12, 2004 | 06:30 AM
bbarbulo's Avatar
Default Re: Turbo help !!!!!!!!!!!!!!!!! (jonbouy)
the answer to all of your questions really depends on how mechanically inclined you are and how good your tuner is... and how much money you are willing to spend. those things considered, I'd prolly have to recommend you put a swap in it, since it doesn't sound like you are mechanically inclined based on your questions. not trying to be a dick, just saying...
Old May 12, 2004 | 06:33 AM
jonbouy's Avatar
Default Re: Turbo help !!!!!!!!!!!!!!!!! (bbarbulo)
iam mechanic so iam guna do the work myself
Old May 12, 2004 | 06:37 AM
bbarbulo's Avatar
well that's great, but it still seems to me you don't know jack about turbos, so the most reliable solution for you would be to swap the motor. unless you are willing to learn and learn and learn about turbo Hondas. there are many examples of long-running turbo Hondas on stock bottom ends. it just takes knowledge, whereas a swap is more or less a simple R&R.
Old May 12, 2004 | 06:43 AM
jonbouy's Avatar
your right i dont no much about turbos thats why iam asking these questions. the reason a went for a turbo because i thought that it would be easier to put one of them on rather than swaping the engine.
Old May 12, 2004 | 06:48 AM
bbarbulo's Avatar
don't worry about it, most ppl assume it's 'easier'. That's why we're here to say, if it's done right, it's NOT easier, and it's NOT cheaper. Sure you can build a shitty DIY kit for $1000, but then you have shitty reliability too. A good PROPER turbo setup should run about $3000+. That includes Hondata, injectors, intercooler, piping, oil lines, coolant lines, fittings, wastegate, BOV, boost controller, gauges, turbo, manifold, turbo timer, and other miscellaneous goodies. And still, you can't be sure you won't blow it all up. ****, now that I think about it, it should be MORE than $3000. I know a guy who just spent $8000 on a custom turbo. :-\ Bottom line is, you get what you pay for.
Old May 12, 2004 | 06:57 AM
jonbouy's Avatar
Default Re: (bbarbulo)
ok then that seems to have of put me off the idea of an turbo now. so what would be the best engine swap for my car were would i get details on how the transplant can be done
Old May 12, 2004 | 07:06 AM
Ya@inlinePRO's Avatar
wrong.
get a used greddy kit. great starter kit for SOHC engines. You can find some used setups for under 1k now i believe.
Old May 12, 2004 | 07:13 AM
jonbouy's Avatar
Default Re: (kwik2nec)
how much horse power would a turbo put on would it be ok on my stock engine
da_coolest
Jul 15, 2009 07:40 AM
acro_acura94
Mar 11, 2005 08:13 AM
Iknownuzzing
Aug 22, 2004 04:20 AM
b18csol
Mar 18, 2002 07:30 PM
