whats the alternator in my 94 accord?
Old May 11, 2004 | 05:16 PM
icculus723's Avatar
Default whats the alternator in my 94 accord?
im trying to figure out what the alternator is in my 94 accord... i want to put in a bigger amp, but it seems to already be taking power from my battery with this 250 watt amp
Old May 12, 2004 | 05:42 AM
Mike813's Avatar
Default Re: whats the alternator in my 94 accord? (icculus723)
get a better battery, a capacitor, and upgrade/clean your grounding points... 250 watt amp your battery should be able to hold that little wattage. get it checked or get a new battery, your stock alternator should be able to hold..
Old May 12, 2004 | 06:42 AM
under advisement's Avatar
Default Re: whats the alternator in my 94 accord? (Mike813)
Agreed, unless it's some pos amp your stock alternator should be able to handle it no problem. I'm running a 300w and 2 150w amps in my 97 and don't have any problems.
Old May 12, 2004 | 08:39 AM
jfastman's Avatar
Max output from your alternator is 80 amps. The alternator doesn't really start "charging" untill the engine rpm is around 2k. You may see your lights dim slightly as the bass hits when your engine is at idle. I would consider this normal. You can install a larger rated battery or some type of capacitor if you feel the need. You can also install a larger pulley on the alternator to speed up the alt. sooner.
tim_r95
Jan 27, 2015 08:02 AM
fomococo
Sep 15, 2011 07:22 PM
doubledee
Jul 27, 2008 02:43 PM
Bulli Kid
Audio / Security / Video
Aug 10, 2007 05:04 PM
accord94
Mar 6, 2003 02:05 PM
