alternator
Old Mar 4, 2003 | 07:54 AM
accord94's Avatar
Default alternator
Does anyone know what the output of a 94 accord ex's sotck alternator is? 2.2L 4 cyl engine. I'm looking at a 135amp alternator but dont know if that will be enough. I'm running 2 300w rms (600w peak) amps and a cda-7893 alpine head unit. thanks
Old Mar 4, 2003 | 08:43 AM
rcurley55's Avatar
New User
Default Re: alternator (accord94)
600W RMS from a typical class a/b amp is in the neighbor hood of 60-80 amps...that's a wide approximation, but that's at maximum current draw.
The stock alternator is probably between 60 and 80, so the 135 would be a healthy upgrade....just make sure to check the idle output of the new alternator...typically they are rated by their peak output...somewhere around 4k rpm.
Old Mar 4, 2003 | 06:46 PM
jokerstud's Avatar
the stock alternator is 65A or 70A depending on the engine
Old Mar 5, 2003 | 03:48 AM
danieldds's Avatar
The alternator upgrade doesnt make a huge difference unless you building a monster system 2000+ watts of power and still even then the difference is not great. Music is not a constant drain it hits peaks and valleys and never draw peak amps for more than milli secs
Old Mar 6, 2003 | 02:05 PM
Gusto222's Avatar
Default Re: alternator (danieldds)
listen to this man- Upgrading your alt is somewhat pointless esp if your only runnin 600w thats nothin.. i had(old-old system) a 1000w ssytem runnin off a 35amp alt - & i had 1farad cap.. it worked fine.
tim_r95
Jan 27, 2015 08:02 AM
lienail
Oct 10, 2012 12:32 AM
BoltonGSR
Jun 22, 2008 07:14 AM
icculus723
May 12, 2004 08:39 AM
