Difference between OBD 0 and OBD 1?
Old Nov 5, 2001 | 06:42 PM
AshlandSi's Avatar
Default Difference between OBD 0 and OBD 1?
Can anyone tell me or provide a link?
I'm looking for specific information.
Old Nov 5, 2001 | 07:06 PM
Katman's Avatar
Default Re: Difference between OBD 0 and OBD 1? (AshlandSi)
one obvious difference is the plug types seen here:
the programming between the two types are different also.
Old Nov 5, 2001 | 08:02 PM
AshlandSi's Avatar
Default Re: Difference between OBD 0 and OBD 1? (Katman)
I mean is there any mechanical difference?
Missing or different sensors?
Certain smog equipment there or not there?
Or is it all in the ECU?
Old Nov 5, 2001 | 08:12 PM
OneThirtyEight's Avatar
I believe there is a difference in where the O2 sensors are located, making OBD 1 slightly better for mods.
Old Nov 6, 2001 | 10:36 AM
Katman's Avatar
well some of the harware on the engine is different..such as the distributor and injector plugs. OBD1 doesn't use that injector relay heatsink anymore either, like on Non-OBD civic/integra's. Like 97blackteg said, there's only 1 02 on OBD1, and two 02 wires on non-OBD B16's for instance.
So it's a mixture of ECU programming and hardware. You can't use OBD1 programming on a non-OBD ECU though.
sixtodc2
Jan 29, 2008 08:28 PM
jdtphotography
Mar 3, 2007 06:54 PM
russianswty
Oct 16, 2006 02:33 PM
twoquickls
May 21, 2002 08:35 PM
