intake manifold, need to indentify sensor
Old May 11, 2004 | 12:43 PM
tilt's Avatar
Default intake manifold, need to indentify sensor
What is this sensor in the bottom left? not the iacv, the one with the black hose running across and up into the manifold. I ask because my 88 crx si manifold doesnt have it.
Old May 11, 2004 | 12:48 PM
4drEF's Avatar
Keyboard Humorist
Default Re: intake manifold, need to indentify sensor (tilt)
Looks like a purge control solenoid if I'm seeing it right. Is there some wires coming off the bottom of it?
What engine is that manifodl from?
Old May 11, 2004 | 12:51 PM
96-EJ6 B18C's Avatar
Bump, I'd like to know as well, I disconnected mine from the vac source and the car didn't run any different.???
EDIT: Mine has the same thing and it is a 90 Si.
Old May 11, 2004 | 12:59 PM
Steve91's Avatar
I believe its called the fast idle solenoid. You don't need it. Just leave it unpluged.
Old May 11, 2004 | 01:04 PM
tilt's Avatar
Default Re: intake manifold, need to indentify sensor (4drEF)
the guy that i bought from listed it as crx si manifold. dunno what year. yeah it has a plug on the end of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">What engine is that manifodl from?</TD></TR></TABLE>
Old May 11, 2004 | 01:09 PM
tilt's Avatar
Default Re: intake manifold, need to indentify sensor (Steve91)
thanks. ill prob end up taking it off and capping the vac line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve91 &raquo;</TD></TR><TR><TD CLASS="quote">I believe its called the fast idle solenoid. You don't need it. Just leave it unpluged.</TD></TR></TABLE>
Old May 11, 2004 | 01:46 PM
onePOINTsix's Avatar
fast idle sel. i ask a while ago about that too
Old May 11, 2004 | 03:03 PM
TiggsCRX's Avatar
so if you don't need it..what does it do in the first place and what will it affect if it's disconnected and plugged?
Old May 11, 2004 | 04:13 PM
CRXDrew's Avatar
it lets ur car warm up w/ a high idle.
I'm 90% sure thats what its for.
Old May 11, 2004 | 04:14 PM
Default Re: (TiggsCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiggsCRX &raquo;</TD></TR><TR><TD CLASS="quote">so if you don't need it..what does it do in the first place and what will it affect if it's disconnected and plugged?</TD></TR></TABLE>
I'll have an answer for you tomorrow...I'm going to try disconnecting mine tonight
Old May 11, 2004 | 05:07 PM
sporkcrx's Avatar
I asked the same thing a while back, here's the thread (although the pic is gone, it's the same sensor you're talking about.
https://honda-tech.com/zerothread?id=569241
I8ayellowcrayon
Jul 14, 2008 01:18 PM
rice a roni
Dec 13, 2006 08:09 PM
tony n.
Jun 29, 2005 09:28 PM
Unjockable
16
Jan 1, 2004 05:11 PM
cr-x si
Mar 14, 2003 07:03 AM
