Oil pan keeps leaking?
Old May 10, 2004 | 09:58 PM
THE GAME IS THICK's Avatar
Default Oil pan keeps leaking?
I've changed the oil pan gasket and i used RTV Sealant on the gasket as it says in a Chiltons manual but that sh*t keeps leaking is there a certain type of RTV stuff i should use for the oil pan? Maybe a high heat kind?
Old May 10, 2004 | 10:57 PM
bleeedawg's Avatar
Default Re: Oil pan keeps leaking? (igotsol!)
make sure you torsque down the screws to appropriate torque. Plus as some sealant to it fo help give it a tighter seal.
Old May 11, 2004 | 07:27 AM
Rtype16's Avatar
Default Re: Oil pan keeps leaking? (bleeedawg)
Take the pan off. Clean both surfaces completely the pan and the block. Make sure the pan is not bent ont he flat surface. Replace gasket. Torque properly and it shouldn't leak. You can also use Hondabond HT.
Modified by Rtype16 at 8:59 AM 5/11/2004
Old May 11, 2004 | 07:48 AM
Ekasey's Avatar
Default Re: Oil pan keeps leaking? (Rtype16)
Yes, there is a particular type of RTV its called HONDABOND, and it works wonders ^_-. take off the pan clean the surfaces, set pan on a falt surface to make sure it isnt warped buy new gasket apply hondabond as specified and gasket. Install pan and torque to specification
Old May 11, 2004 | 10:32 AM
APEX CRX's Avatar
Default Re: Oil pan keeps leaking? (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, there is a particular type of RTV its called HONDABOND, and it works wonders ^_-. take off the pan clean the surfaces, set pan on a falt surface to make sure it isnt warped buy new gasket apply hondabond as specified and gasket. Install pan and torque to specification</TD></TR></TABLE>
most common is to over torque the gasket and squeeze it causing oil to leak
Old May 11, 2004 | 10:36 AM
Zerob16eg's Avatar
Hondabond only! also i think the oil pan nuts are rated for inch pounds not foot pounds.....you will need a torque wrench calibrated to inch pounds.
Old May 11, 2004 | 03:53 PM
Default Re: (Zerob16eg)
does anyone know the part# or can i just go to honda parts dept. and ask for "hondabond"?
Old May 11, 2004 | 11:27 PM
Default Re: (igotsol!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotsol! &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know the part# or can i just go to honda parts dept. and ask for "honda bond"?</TD></TR></TABLE>
bump... need more info on the honda bond
peace
Old May 12, 2004 | 06:09 AM
DaX's Avatar
DaX
Loved
Community Favorite
Just go ask for Hondabond at the parts counter.
I don't torque down my oil pan...I run it up by hand, then add 1/4 to 1/2 turn to each. No more leaks. I've found that the spec of 9 ft-lbs is too much.
Old May 20, 2004 | 12:15 PM
SIK IN DA HED's Avatar
New User
when you guys apply hondabond, do you apply it thinly to each side of the gasket? ie: between the gasket and pan... between the blobk and gasket... so there is sealant to both pressure areas?
Old May 20, 2004 | 12:24 PM
Ekasey's Avatar
Default Re: (SIK IN DA HED)
yes both sides of the gasket but not too muhc but enough hard to explain you gotta feel it out
Old May 20, 2004 | 12:34 PM
New User
Default Re: (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">yes both sides of the gasket but not too muhc but enough hard to explain you gotta feel it out</TD></TR></TABLE>
maybe we didnt apply it as well as we thought. its leaking on the thinner side of the oil near the flywheel. turns into a puddle after 5 minutes.
Old May 20, 2004 | 12:45 PM
RCautoworks's Avatar
Did you pound the dimples out ? If not, when you tightin the gasket you will tear it.
Old May 20, 2004 | 02:52 PM
New User
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Did you pound the dimples out ? If not, when you tightin the gasket you will tear it.</TD></TR></TABLE>
pound what dimples?
my friend installed the oil pan. i applied the hondabond and put the gasket on.
Old May 20, 2004 | 03:05 PM
When you put an oil pan on and torque the bolts the pan bends a little making dimples. Well the dimples face up towards the engine and if its at the right angle the metal can be pretty sharp. So if you don't pound the dimples out the next time you put the pan on, the dimples push against the gasket causing it to tear. The dimples look like this
______/ \________
Old May 20, 2004 | 03:12 PM
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">When you put an oil pan on and torque the bolts the pan bends a little making dimples. Well the dimples face up towards the engine and if its at the right angle the metal can be pretty sharp. So if you don't pound the dimples out the next time you put the pan on, the dimples push against the gasket causing it to tear. The dimples look like this
______/ \________ </TD></TR></TABLE>
got it
Old May 20, 2004 | 08:34 PM
Dual Cams's Avatar
when you take off the oil pan, make sure all surface is clean, and just put honda bonds on the edges. that should do it
Old May 21, 2004 | 05:26 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIK IN DA HED &raquo;</TD></TR><TR><TD CLASS="quote">
maybe we didnt apply it as well as we thought. its leaking on the thinner side of the oil near the flywheel. turns into a puddle after 5 minutes.</TD></TR></TABLE>
Are you 100% Positive you got the little metal rings off the studs when removing the old gasket. This is really what this sounds like.
Old May 21, 2004 | 07:47 AM
New User
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">
Are you 100% Positive you got the little metal rings off the studs when removing the old gasket. This is really what this sounds like.</TD></TR></TABLE>
yes. i checked it yesterday. its just a bad seal.
Old May 21, 2004 | 02:32 PM
Chiovnidca's Avatar
Sure it's not the main seal leaking?
Old May 21, 2004 | 02:41 PM
yes. i checked it yesterday. its just a bad seal. </TD></TR></TABLE>
What seal ? Main or oil pan ( oil pan gasket ) ?
StreetRacinThug
Dec 21, 2006 08:44 AM
rewerbcrx
Dec 15, 2005 05:34 PM
mstewar
Aug 1, 2005 10:50 PM
Lucky_Smurf
Feb 8, 2005 04:46 PM
deconstruct
Jun 18, 2004 01:00 PM
