Oil Pan install
Do you put it on both the oil pan and the block? In the past on other cars I've only put it in the corners of the pan to secure the gasket. Oh i'm using a stud kit for the pan as well.
According to the FSM it is 8 pounds/foot (96 pounds/inch) for the B18C. It also says to apply liquid gasket (Hondabond) (p/n 08718-0001 ) to the mating surfaces on the right side cover and the oil pump housing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Cow »</TD></TR><TR><TD CLASS="quote">do not over tighten. 8-10ft/lbs is NOTHING</TD></TR></TABLE>
Yup, in fact I would use a beam type torque wrecnh which usually come in LBS/INCH. That's why I included that number above. You'll also be less likely to overtorque it with one of those.
8 ft/lbs = 96 in/lbs.
StreetRacinThug
Dec 21, 2006 08:44 AM
deconstruct
Jun 18, 2004 01:00 PM
