Removing Intank fuel pump
Old Nov 5, 2001 | 12:47 PM
LsTurbo91's Avatar
Default Removing Intank fuel pump
According to my helms manual I have to remove the fuel tank to remove the fuel pump? Is there any way to avoid this?
Old Nov 5, 2001 | 02:18 PM
LsTurbo91's Avatar
Default Re: Removing Intank fuel pump (LsTurbo91)
Old Nov 5, 2001 | 02:19 PM
4dGSR at work's Avatar
hell ya
ls as in integra?????
change it when the tank is low
remove the back seat....
unscrew nuts.....
remove tubes.... have a rag(lil leaky)
and bam you at the pump
detach above tank....
plug in new pump....
should take 30 mins at most,
hardest part.... make sure the clips are bent tight to hold the seat down or bolt the middle bolt on the bench
Old Nov 5, 2001 | 02:26 PM
LsTurbo91's Avatar
Default Re: Removing Intank fuel pump (4dGSR at work)
so you do have to remove the damn tank eh! DOH!
Old Nov 5, 2001 | 04:10 PM
FAST94GSR's Avatar
New User
NO you don't have to remove the fuel tank. you can get to it from the top by removing the rear seat like the other dude just said.
Old Mar 16, 2005 | 08:16 AM
elpiar's Avatar
Default Re: Removing Intank fuel pump (FAST94GSR)
Anyone has pictures of this procedure?
Old Mar 16, 2005 | 08:28 AM
Doodoo's Avatar
If you have a 4g civic/CRX then you have to drop the tank. Make sure its almost empty if you do. It can be heavy with alot of gas.
Old Mar 16, 2005 | 10:21 AM
adseguy's Avatar
Default Re: Removing Intank fuel pump (Doodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar &raquo;</TD></TR><TR><TD CLASS="quote">Anyone has pictures of this procedure?</TD></TR></TABLE>
http://www.c-speedracing.com/h...p.php
They have a lot of how to's....also try SEARCHING!
Old Mar 16, 2005 | 10:29 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Removing Intank fuel pump (elpiar)
you bump a 4 year old thread for pictures...
Old Mar 19, 2005 | 06:33 PM
chunk's Avatar
er.... on a 91 Integra you DO have to drop the tank. The layout changes in 94 i belive so you no longer needed to.
Before you start i'd suggest you run the tank as close to empty as possible.
on a G2:
1. take out the back seat, unplug the wiring and push the gromet thru so it falls free.
2. remove plastic cover under car next to fuel tank, under you will find the fuel lines, disconnect, I think there are 3 of them. Also disconnect the fuel tank fill hose and vent hose. If you are having troubles with the lines, you can do most of step 3, lower the tank a bit with the jack and then work the lines.
3. brace fuel tank with jack, remove 2 bolts holding tank straps in. Should be able to drop the tank, you need to clear the exhaust in the front and on the pass side so kind of angle it out.
4. on the top of the now removed fuel tank remove round metal plate that all the lines you just disconnected went to and slowly pull out the pump, may need to turn it a bit.
Install is reverse, a second pair of hands makes putting the tank back in MUCH easier.
Old Mar 19, 2005 | 07:06 PM
NJIN BUILDR's Avatar
Default Re: Removing Intank fuel pump (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">
you bump a 4 year old thread for pictures... </TD></TR></TABLE>
Damn ..I always miss the dates...lol
enjoi_hendrix
Sep 7, 2009 07:41 AM
white99CF
Sep 3, 2006 09:13 AM
Joeyt426
Aug 1, 2006 01:55 PM
Mike1486
Sep 24, 2004 11:19 AM
SpeedMonkeyRacing
Nov 29, 2002 06:08 AM
