SOHC zex nitrous decision AGAIN!!!!
Old May 9, 2004 | 04:57 PM
speedehatch's Avatar
Default SOHC zex nitrous decision AGAIN!!!!
Well im almost certain that i am going to be getting a zex kit and spraying a 65 shot. My question which should i buy dry or wet? I think wet is so much safer and i have less to worry about since it does fuel also. What about a dry kit, are they not that great, all the ones on ebay are all dry, i cant find any wet kits for like 300-350 shipped but dry kits are selling for that much. What are you SOHC guys using. Any info would be nice. Think with my mods i can hit 14s and with a 65 shot?
Old May 9, 2004 | 05:58 PM
Default Re: SOHC zex nitrous decision AGAIN!!!! (speedehatch)
bump
Old May 9, 2004 | 06:08 PM
HondaAccordSiR's Avatar
try a quick search, this topic is pounding every month here
Old May 9, 2004 | 09:02 PM
egcivic94's Avatar
I was running a ZEX dry kit on my D16Z6, I had no problems running the 75 shot, I race at my local 1/8 mile track and ran a E.T of 9.35@77MPH I just retarded the timing by 2 degrees and used the ZEX plugs, standard bolt ons and a MSD SCI plus ignition/w blaster SS coil I drive my car daily and the only thing I replaced was the head gasket. good luck, oh I never ran the 1/4 in that set up but that would be a mid to high 14.
Old May 9, 2004 | 10:33 PM
RyanEJ8's Avatar
Dry kit is better than a single fogger wet kit, IMO. No risk of fuel puddling.
Old May 9, 2004 | 10:38 PM
11psiTurboSI's Avatar
Default Re: SOHC zex nitrous decision AGAIN!!!! (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">Dry kit is better than a single fogger wet kit, IMO. No risk of fuel puddling.</TD></TR></TABLE>
I rather run rich with more fuel then lean out with nitrous oxide only!
Old May 9, 2004 | 10:48 PM
RyanEJ8's Avatar
Default Re: SOHC zex nitrous decision AGAIN!!!! (9psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">
I rather run rich with more fuel then lean out with nitrous oxide only!</TD></TR></TABLE>
A dry kit adds fuel by raising the fuel pressure. If it didn't add fuel to compensate for the nitrous you would lean out and melt your engine INSTANTLY with a 55 shot. Did you actually think a dry kit just sprays nitrous into the combustion chamber with no fuel to compensate for the added nitrous?
Old May 9, 2004 | 11:28 PM
yea like my friend's Zex kit came with a purple box and even he mess up his ringlands with the dry kit with his h22a with colder plugs and 75 shot!
Old May 9, 2004 | 11:32 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">yea like my friend's Zex kit came with a purple box and even he mess up his ringlands with the dry kit with his h22a with colder plugs and 75 shot!</TD></TR></TABLE>
really? weird, i typically see this happen when people stick the wrong fuel jet in the brain..
mike
Old May 9, 2004 | 11:36 PM
Default Re: SOHC zex nitrous decision AGAIN!!!! (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">
mike</TD></TR></TABLE>
Well his kit came with a 55, 65, and 75 shot. So he couldn't have put a bigger jet in
MikeMAN's Avatar
i said FUEL jet..not nitrous jet
mike
Old May 10, 2004 | 07:07 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">i said FUEL jet..not nitrous jet
9psiTurboSI doesn't seem to understand that a dry nitrous kit has fuel jets.
90B16aCRXsi
Nov 28, 2007 11:25 PM
STEV3-O
May 19, 2003 08:12 AM
BLK JDM
Feb 26, 2003 08:17 AM
GreenBean
20
Oct 1, 2002 11:54 AM
BEEFEDUPACCORD
Mar 11, 2002 10:30 AM
