brakes
Old May 9, 2004 | 04:56 PM
bOOsTiNSoHcVtEc's Avatar
Default brakes
For some reason my brake pedal is stiff how it should be wen u press it and sometimes it gets spongey...like i press it and it keeps goin farther and farther down and i have to press it harder. Whats going on? I changed my brake pads in the front but I havent in the rear...can someone help me?
Old May 9, 2004 | 09:45 PM
Default Re: brakes (bOOsTiNSoHcVtEc)
Old May 9, 2004 | 09:50 PM
boostn420's Avatar
you didnt open any brake lines or bleeder valves did you? If so there may be air in the system and it will need to be bled.
Old May 9, 2004 | 11:20 PM
Default Re: brakes (boostn420)
nope didnt open any brake lines or bleeder valves
Old May 10, 2004 | 08:04 AM
eLusive Acclude's Avatar
Technically everytime you install brake pads you should open the bleeder screw when you are depressing the caliper piston back into the caliper. This will ensure that there is no air trapped and it will also get rid of the fluid thats been in there. Try bleeding your brakes first off, if that doesn't solve the problem then it could be one of the seals internally leaking in your master cylinder.
Old May 10, 2004 | 09:39 AM
Default Re: brakes (eLusive Acclude)
Ill try to bleed the system one of these days. It started happening wen my brakes were almost dead though..b4 I changed the brakes, if that helps any..
Old May 10, 2004 | 12:33 PM
hondatechnician's Avatar
do not open ur bleeder screw when changing ur brake pads if u do air gets it what u could do is open ur master cylinder so that the fluid spills out if u dont want fluiding spillin' out u can use a baster(kitchen utensil) and suck some of out of ur m.c.
Old May 10, 2004 | 12:36 PM
sounds like a busted caliper. check the caliper piston for a bust rubber seal and if fluids comin' out of it
Old May 10, 2004 | 02:51 PM
Default Re: brakes (hondatechnician)
OK LET ME BE MORE CLEAR, when you open the bleeder screw have a bleeder bottle hooked up to it that way you dont get air in the lines i thought that would be sort of self explanatory but maybe not to mr honda technician who can not justify his reasons
Old May 10, 2004 | 06:04 PM
wen i did my brake pads the caliper piston looked fine...no fluids were coming out and the rubber looked fine
Old May 10, 2004 | 06:10 PM
do u think it could have something to do with the brake booster or brake booster check valve?
Old May 10, 2004 | 07:24 PM
neither, brake boosters rarley go bad and what check valve?
Old May 10, 2004 | 07:41 PM
the plastic valve between the brake vaccum line and the brake booster
Old May 10, 2004 | 10:27 PM
doubt thats it casue that just to provide vacuum to the booster it would just become overly stiff but wash it out with sopa and water if it makes you feel better
Old May 11, 2004 | 12:55 PM
ok as far as b. booster when they go bad ur brakes lock....this means anything in ur booster and the hose connect to it(booster have no fluids going though it) it might be ur m.c did u check the rear hose caliper & or wheel cylinder since a sponge pedal equals air in ur system somewhere were fluid is present
and about the bleedin while ur changin' pads that stuff will get u fired at a shop
plumdusty
Feb 28, 2019 04:46 PM
xkrazyxjbrkerx75
13
Jul 16, 2011 04:27 PM
mshields4129
Jun 18, 2011 06:18 PM
K24_Y61P
Suspension & Brakes
12
Nov 9, 2008 05:21 PM
flipmodemvp
Mar 17, 2007 10:34 PM
