Closer to 11's..
Went to the track today and got some improved times even though it was 90 degrees out. Best run was 12.17 at 115mph. Setup is a bone stock B16, bolt on DRAG kit with FMU and inline pump (and Deltagate) at 9psi in a 92 Civic VX running 22x8 slicks. Also drove 200 miles round trip to the track
Next time I may try a night race with some cooler temps and see if I can hit 11's before I do some more mods. Might have a vid up soon also of one of my runs
Damn,Matt...You need to dump that b16 for a ls motor to run 11s...
...J/K...Bad *** times for such low boost!!!!Keep it up, you definately got the mph for high 11s...
I think he was hitting high 1.7s.
Congrats Matt. Maybe you should put those 24x13x8 inch slicks sitting on the floor at the shop to good use
I bet you'll hit 11s with those-less shifting, more time in the power band, and a better 60ft equals 11s easily!
Can't wait to see you kick some butt at OVIS.
Steve K.
I bet you'll hit 11s with those-less shifting, more time in the power band, and a better 60ft equals 11s easily!Can't wait to see you kick some butt at OVIS.
Steve K.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr »</TD></TR><TR><TD CLASS="quote">Damn,Matt...You need to dump that b16 for a ls motor to run 11s...
Thanks, I wish I had the stong bottom end of the LS to be able to run 15lbs but i'm not ready to test the limits of my B16 bottom end yet
</TD></TR></TABLE>Thanks, I wish I had the stong bottom end of the LS to be able to run 15lbs but i'm not ready to test the limits of my B16 bottom end yet
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">
pushing the limits of the stock block i would say the b16 will def hold more power.
</TD></TR></TABLE>pushing the limits of the stock block i would say the b16 will def hold more power.
westcoaststyle
36
Nov 16, 2003 09:34 AM
