Closer to 11's..
Old May 8, 2004 | 03:00 PM
nsxmatt's Avatar
Default Closer to 11's..
Went to the track today and got some improved times even though it was 90 degrees out. Best run was 12.17 at 115mph. Setup is a bone stock B16, bolt on DRAG kit with FMU and inline pump (and Deltagate) at 9psi in a 92 Civic VX running 22x8 slicks. Also drove 200 miles round trip to the track
Next time I may try a night race with some cooler temps and see if I can hit 11's before I do some more mods. Might have a vid up soon also of one of my runs
Old May 8, 2004 | 03:02 PM
Casey's Avatar
Default Re: Closer to 11's.. (nsxmatt)
awesome awesome times man...need to update your sig
Old May 8, 2004 | 03:08 PM
nsxmatt's Avatar
Default Re: Closer to 11's.. (Casey)
Woops! Done
Old May 8, 2004 | 04:48 PM
TurboJesse
Guest
Posts: n/a
nice...talk about K.I.S.S
Old May 9, 2004 | 04:14 AM
nsxmatt's Avatar
Default Re: Closer to 11's.. (Mpir3)
Thanks, I try!
Old May 9, 2004 | 04:30 AM
paul93sir's Avatar
nice going with some cooler weather u will definitly be in the 11's
Old May 9, 2004 | 03:41 PM
warwagon's Avatar
you got elevens, lets get some uber in that thing you have got to!!!!!!!
oh yeah and i want to see some footage
Old May 9, 2004 | 06:02 PM
Civic_95_Si's Avatar
Default Re:
Good job.1/8th ET and trap?
Old May 9, 2004 | 06:16 PM
nsxmatt's Avatar
Default Re: Re: (Civic_95_Si)
1/8th was 7.83 at 92.12
Old May 9, 2004 | 07:01 PM
Purepower87's Avatar
sweet, quick civic you got there
Old May 9, 2004 | 08:43 PM
phcnfast's Avatar
How many psi are you running?
Old May 10, 2004 | 03:09 AM
nsxmatt's Avatar
Default Re: (phcnfast)
9 psi
Old May 10, 2004 | 03:18 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (nsxmatt)
Awesome times for a stock motor with a Drag kit
Old May 10, 2004 | 11:01 AM
99lspwr's Avatar
Default Re: (HybridHatch88)
Damn,Matt...You need to dump that b16 for a ls motor to run 11s... ...J/K...Bad *** times for such low boost!!!!Keep it up, you definately got the mph for high 11s...
Old May 10, 2004 | 11:03 AM
99lspwr's Avatar
Default Re: (99lspwr)
BTW, What was your 60 ft?????I would guess somewhere in the low 1.9 range..
Old May 10, 2004 | 11:14 AM
Evill Supra's Avatar
I think he was hitting high 1.7s.
Congrats Matt. Maybe you should put those 24x13x8 inch slicks sitting on the floor at the shop to good use I bet you'll hit 11s with those-less shifting, more time in the power band, and a better 60ft equals 11s easily!
Can't wait to see you kick some butt at OVIS.
Steve K.
Old May 10, 2004 | 11:22 AM
99lspwr's Avatar
Default Re: (Evill Supra)
Damn...Seemes like he should be in the 11.90 range with that 60 ft....
Old May 10, 2004 | 04:27 PM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr &raquo;</TD></TR><TR><TD CLASS="quote">Damn,Matt...You need to dump that b16 for a ls motor to run 11s... ...J/K...Bad *** times for such low boost!!!!Keep it up, you definately got the mph for high 11s... </TD></TR></TABLE>
Thanks, I wish I had the stong bottom end of the LS to be able to run 15lbs but i'm not ready to test the limits of my B16 bottom end yet
Old May 10, 2004 | 04:33 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks, I wish I had the stong bottom end of the LS to be able to run 15lbs but i'm not ready to test the limits of my B16 bottom end yet </TD></TR></TABLE>
pushing the limits of the stock block i would say the b16 will def hold more power.
Old May 10, 2004 | 05:40 PM
allmota1.8's Avatar
Default Re: (Mpir3)
get hondata and turn the boost up!!!!!!!!!!!!
crazyimport
Oct 9, 2005 09:03 AM
nsxmatt
Sep 15, 2004 07:30 AM
nsxmatt
Apr 16, 2004 05:58 PM
westcoaststyle
36
Nov 16, 2003 09:34 AM
nsxmatt
Feb 2, 2003 06:54 PM
