Parts for b16 swap
Old May 7, 2004 | 04:39 AM
cjoyce's Avatar
Default Parts for b16 swap
im planning on putting in the b16a motor with 160 hp and 111 ft/torque into a 92-95 hatchback....now what im wondering is what parts besides the motor, transmission, and ecu i will need to get or replace in order for the motor to run. and fit perfectly..thankyou for any help
Old May 7, 2004 | 05:05 AM
Harassing Herbs's Avatar
Default Re: Parts for b16 swap (cjoyce)
if the hatch is a Si or a Vx you have all u need its a direct swap.
far as the Cx/Dx you have to run the wires for the vtec/vtec oil pressure.
the next is depending on what ecu you are going to run the car with. if you use a chipped p28 you don't have to wire the knock sensor. if you use a p72 you must wire the knock sensor in to the ecu.
if you got a lil extra cash just buy an integra or 92-95 (si,ex,vx) engine harness then you don't have to wire anything just plug & play.
Old May 7, 2004 | 06:40 AM
cjoyce's Avatar
Default Re: Parts for b16 swap (Harassing Herbs)
ok you talked about the ECU...the motor comes with the ECU would that be all set to swap right in or would it need modifying as well....also..if i got the dx hatchback what might i need to have a successful swap..thank you ver much for all the help
Old May 7, 2004 | 06:47 AM
cjoyce's Avatar
to add to my above post....what would i need for mounts for the engine...and is there anything else i would need...i just want to be able to have everything i need to do the swap and not have to keep buying parts and have it take forever to do the swap..thanks again
Old May 7, 2004 | 06:58 AM
if u can get one of those engine harness would be the easiest way, since it has the vtec wires in there already. you may just have to wire a knock sensor since 92-95 did not use one. once u get the ecu there will be a code on it. any vtec ecu besides the p28 you will neet to wire a knock sensor.
you can use your stock mounts.
Old May 7, 2004 | 07:36 AM
cjoyce's Avatar
i take it the b16 manual transmission and all the exhaust components will hook up fine? sorry for asking all these question i just dont want to get blind sided when i go to do the swap..thanks again
Old May 7, 2004 | 07:39 AM
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjoyce &raquo;</TD></TR><TR><TD CLASS="quote">i take it the b16 manual transmission and all the exhaust components will hook up fine? sorry for asking all these question i just dont want to get blind sided when i go to do the swap..thanks again</TD></TR></TABLE>
Yes. Everything you need for the complete swap:
http://www.hmotorsonline.com/s...30005
- Motor
- Hydraulic Tranny (S21, Y21)
- ECU (P30)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- All Sensors
Eglifestyle
Feb 13, 2006 08:16 PM
Session101
Dec 4, 2003 09:59 AM
crazydude75927
Mar 14, 2003 09:32 PM
TurboBumblBee
Feb 25, 2002 06:03 PM
jonnybravo
Feb 25, 2002 05:58 PM
