EGR problem
Old Nov 4, 2001 | 03:44 PM
Backyard Speical's Avatar
Default EGR problem
hey whats up guys does anyone know how to trick the EGR code? got a h22a motors thats in a 93 civic, but couldn't wire up the EGR.... any help would be great
Old Nov 4, 2001 | 04:54 PM
fixhondas's Avatar
Default Re: EGR problem (Prodigy 2.2 EK)
Which ecu are you using?
Old Nov 4, 2001 | 09:29 PM
Default Re: EGR problem (fixhondas)
i'm using the h22a ecu right now. so the computer reads egr, and i don't really want to run a gsr or p28 ecu
[Modified by Prodigy 2.2 EK, 6:30 AM 11/5/2001]
Old Nov 5, 2001 | 12:09 PM
fixhondas's Avatar
what year is the megine/ecu from?
Old Nov 5, 2001 | 12:10 PM
92-95 prelude vtec, OBD1
Old Nov 5, 2001 | 12:19 PM
fixhondas's Avatar
you are going to need a CVC valve and frequency solenoid from a prelude. It is located on the driver's side fender area. It will have vacuum hoses going to it and it will have a black bracket. The CVC valve is green and white.
Old Nov 6, 2001 | 09:42 PM
i got it already so whats would be the next step???
Old Nov 7, 2001 | 12:11 PM
fixhondas's Avatar
You need to hook it up. There should be a connector for the solenoid from the wire harness. Hook up a vacuum line from the manifold to the CVC valve. Hook up the solenoid hose to the egr line.
komet 163
Jul 5, 2016 01:47 PM
tr0n9h
Oct 4, 2005 09:12 PM
tr0n9h
Oct 4, 2005 07:13 PM
tomtom211
Jan 14, 2003 08:13 PM
Backyard Speical
Nov 4, 2001 09:31 PM
