b16 blcok w/ gsr head good for turbo?
Old May 6, 2004 | 09:38 AM
showtymers619's Avatar
* B A N N E D *
Default b16 blcok w/ gsr head good for turbo?
like what th etopic ses.. i hear that combination is concidered hi comp. can any1 clear this up for me. im planning to finish up my set up if possible, my set up will consist of
air to water intercooler
vafc w/rc370cc
small t3 from a volvo on 7 psi till i get it on a dyno and get my hondata
Old May 6, 2004 | 03:13 PM
* B A N N E D *
Default Re: b16 blcok w/ gsr head good for turbo? (ShowTymers619)
any1 got this set up b16 block gsr head?
Old May 8, 2004 | 12:14 PM
Garcia-Racing's Avatar
worked fine for me. 9:1 pistons
Old May 10, 2004 | 06:08 AM
* B A N N E D *
Default Re: b16 blcok w/ gsr head good for turbo? (TGARCIARACING)
i ment it by stock compression
Old May 10, 2004 | 06:41 AM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShowTymers619 &raquo;</TD></TR><TR><TD CLASS="quote">like what th etopic ses.. i hear that combination is concidered hi comp. can any1 clear this up for me. im planning to finish up my set up if possible, my set up will consist of
vafc w/rc370cc
small t3 from a volvo on 7 psi till i get it on a dyno and get my hondata</TD></TR></TABLE>
well, according to..
http://www.c-speedracing.com/h...c.php
stock b16 is 10.2
stock usdm b16 block with C1 head is about 10.4
there are many people who have turboed there stock R's which are at CR of 10.6
so your CR of 10.4 is ok.
Old May 10, 2004 | 07:07 AM
* B A N N E D *
Default Re: b16 blcok w/ gsr head good for turbo? (-iLLuZioN-B18C1)
coo
Old May 10, 2004 | 07:22 AM
m R g S r's Avatar
I am gonna run this setup with cp 9:1 pistons. It should be around 9.2:1 with the p72 head.
Old May 13, 2004 | 07:13 PM
B18Tahtaras's Avatar
But why would you run this type of setup... why not just stick with a b16 head with gsr cams? B16 heads are known to flow better.
Old May 13, 2004 | 07:20 PM
boosted92's Avatar
Default Re: b16 blcok w/ gsr head good for turbo? (B18Tahtaras)
They flow basically the same stock, they flow basically the same modded. Not going to notice the difference on a street car between either one, especially not on a turbo street car.
Old May 13, 2004 | 08:16 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Tahtaras &raquo;</TD></TR><TR><TD CLASS="quote">But why would you run this type of setup... why not just stick with a b16 head with gsr cams? B16 heads are known to flow better. </TD></TR></TABLE>
the reason why im running this set up becasue i got a fully built gsr head for cheap...
ported ports intake and exhaust.. polished exhaust ports
dual valve springs
ferrea valves
jun retainers
and my fuel manage ment changed to uberdata
i think the only thing else to really do is mill it down which its something i dotn want
and get 5 angle cut valves and seats
Old May 20, 2004 | 07:47 PM
DTSbmxKID's Avatar
putting a gsr head on a b16 block highers your compression .2, the combustion chamber on a gsr head is smaller than that of a b16 head by about 1cc. If there is port work done the chamber may have had its size changed during the process. I say stick with the b16a head. It came on that motor for a reason. If the reason you are switching is because of the portwork then take the head somewhere and have the combustion chamber re-shaped for lower compression and it will be better than your b16a head(compression wise).
Old May 21, 2004 | 02:31 PM
wow...
MORE POWER TO YA... LITERALLY! HAHA
Day-DayC
Sep 25, 2006 08:18 AM
Rhymenoceros
Aug 6, 2006 07:04 AM
hondanut101
May 18, 2005 02:58 PM
10seceg
Jul 26, 2004 06:46 AM
othick
Jul 9, 2003 11:24 AM
