Troubleshoot: Steering wheel shakes
steering wheel shakes......
while driving around, my pass. side front wheel hits bumps with a thump (which causes my steering wheel to shake). even while taking a hard right turn shakes the steering wheel
done list:
alignment
replaced lower ball joints
replaced upper A-arms
replaced tie rod ends
rebalanced wheels
(shook the wheels, ok wheel bearings)
need some advise
thanks
done list:
alignment
rebalanced wheels
need some advise
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eluder200K »</TD></TR><TR><TD CLASS="quote">Shocks?</TD></TR></TABLE>
Maybe bad axle as well.
Integra Type-R forum?
cant post in suspension forum....and type r people are cooler
I have a shake also 70+mph. 92 hatchback
It has had shakes on 2 diff suspensions, balljoints are months old and bolts are all good. So possibly/probably not shock related (although bump could be).
Any ideas to troubleshoot are appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">I have a shake also 70+mph. 92 hatchback
Any ideas to troubleshoot are appreciated.</TD></TR></TABLE>
Sounds like a possible inner cv joint problem to me. That is the most common side effect
https://honda-tech.com/zerothread?id=664016
I had a vibration problem that sidelined my kah for almost 2 years. I replaced:
left driveshaft
right driveshaft
tranny
brakes
knuckles
A arms
driveshafts again
It seems that I've actually finally fixed the problem. I originally replaced the driveshafts with remanned ones done by a local company called Fenco. I have major problems with them. I replaced a mushroomed OEM shaft with one of theirs and it broke at the track after 2 weeks. I got it replaced under warranty, then it broke again within 2 weeks, but this time on the street. I had it replaced with a frankenstein shaft, which eventually wore down to cause my vibration. I replaced both shafts with replacement Fenco shafts and the vibration persisted.
Basically, that company has caused me so much grief. In a nutshell, grab a couple shafts from a wrecker if you're just diagnosing. A non-VTEC shaft is fine as long as the ABS encoder ring is on. I got mine for $65 canadian each. If that's the problem you might want to grab a fancy shaft from one of the manufacturers someone else will recommend.
left driveshaft
right driveshaft
tranny
brakes
knuckles
A arms
driveshafts again
BauleyCivic
11
Oct 11, 2004 09:14 PM
Faust
Jun 18, 2003 07:06 AM
dgc92civic
17
Apr 30, 2003 10:37 PM
