help, no vtec and early redline, no CEL's
Old May 5, 2004 | 06:44 PM
Timmay's Avatar
Default help, no vtec and early redline, no CEL's
99 DX
d16y8 swap
99-00 P2P ECU
did all the right changes to the wire harness
wired vtec(checked over and over again)
wired knock
now im not getting vtec and redline is at 6800 which is early
NO CEL's
ive tried a different ecu vtec solenoid and vtec oil pressure switch with no luck
ahhhhhh its so frustrating
help anyone???
Old May 5, 2004 | 09:26 PM
Timmay's Avatar
Default Re: help, no vtec and early redline, no CEL's (Timmay)
just tried another vtec oil pressure switch, still no work
Old May 6, 2004 | 12:37 AM
gundamgsr's Avatar
how is your dis. cap and rotor? and plugs?
Old May 6, 2004 | 09:54 PM
Timmay's Avatar
Default Re: (gundamgsr)
pretty sure they are ok
oh and im using the DX dizzy
Old May 9, 2004 | 12:05 AM
Timmay's Avatar
bump
Old May 9, 2004 | 12:10 AM
tegon-gsr's Avatar
oil?
Old May 9, 2004 | 12:16 AM
Timmay's Avatar
Default Re: help, no vtec and early redline, no CEL's (tegon-gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegon-gsr &raquo;</TD></TR><TR><TD CLASS="quote">oil? </TD></TR></TABLE>
right on the money full.
Old May 9, 2004 | 03:21 PM
Timmay's Avatar
i am all out of ideas here
Old May 13, 2004 | 09:24 PM
polymath's Avatar
I've had this same problem on a d16z w/p28 ecu...except the redline will vary from 4400 to 6000 depending on temperature. No CELs either...
A friend said to check the clearances on the sensors in the bottom half of the distributor...I haven't tried this yet.
got_no_sol
Apr 11, 2008 08:51 PM
JDM-MONKEY
Jan 14, 2006 10:10 AM
quicky_hatch12
Aug 20, 2005 07:55 PM
AdamITR
Apr 17, 2003 03:00 PM
AdamITR
Apr 14, 2003 04:38 PM
