how to attach my oil feed line?K26 turbo
Old May 5, 2004 | 12:10 PM
jure's Avatar
Default how to attach my oil feed line?K26 turbo
My K26 turbo has the oil feed hole with two threaded holes on each side, so it looks like I need some adapter to attach a fitting to it?I saw that some turbos were hook up without adapter flange..Do I need flange for my turbo??
Here's a pic..
Old May 5, 2004 | 12:52 PM
Muckman's Avatar
Moderator in Chief
Default Re: how to attach my oil feed line?K26 turbo (jure)
Old May 5, 2004 | 01:02 PM
TurboCX's Avatar
Default Re: how to attach my oil feed line?K26 turbo (Muckman)
The one you just showed him is for the return line. He needs to purchase a similar flange but with a smaller hole for the oil feed fitting.
Old May 5, 2004 | 01:03 PM
Civic Power's Avatar
New User
I think The kit above includes everything u need for the oil feed line. No u don't need a flange for it .
Modified by Civic Power at 2:27 PM 5/5/2004
Old May 5, 2004 | 01:18 PM
boosted_dc2's Avatar
Default Re: how to attach my oil feed line?K26 turbo (Civic Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Power &raquo;</TD></TR><TR><TD CLASS="quote">Isn't that for the oil return line to the pan ?
The kit above includes everything u need for the oil feed line. No u don't need a flange for it . The oil feed hole on the turbo is 1/8 npt </TD></TR></TABLE>
WRONG, not all turbos are the same. you might need a fitting, but that may be the return port, what does the other side look like??? if tha is the inlet then you will need a fitting like^^^ but it has a smaller hole in it.
Landon
Old May 5, 2004 | 01:32 PM
jure's Avatar
Default Re: how to attach my oil feed line?K26 turbo (boosted_dc2)
This is 1000% feed side of the turbo, return side is the same, only a bigger hole..
This hole is no threaded on the picture above..How to hook feed line into this no threaded hole?
Old May 5, 2004 | 02:13 PM
Matt B's Avatar
http://cgi.ebay.com/ebaymotors...=WDVW
this looks like what you need
Old May 5, 2004 | 06:41 PM
TurboCX's Avatar
Modified by Civic Power at 2:27 PM 5/5/2004</TD></TR></TABLE>
Wrong. That kit does not include what he needs. He does need a flange for the inlet. Most turbos come with the oil inlet already threaded. Some do not and require you to purchase a flange so you can screw the fitting on. Jure posted the picture of his turbo and that is the inlet that he showed. Jure's turbo requires that flange.
Old May 5, 2004 | 06:55 PM
TurboCX's Avatar
Default Re: how to attach my oil feed line?K26 turbo (Matt B)
The flange MattB showed you is the correct flange. You can also purchase the flange that has a threaded hole and you add the fitting. Both work. Good luck.
Old May 5, 2004 | 07:46 PM
xenocron's Avatar
...or
...and...
Old May 5, 2004 | 08:21 PM
Hoosier Daddy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
That's a return flange
Old May 5, 2004 | 08:59 PM
New User
Default Re: how to attach my oil feed line?K26 turbo (TurboCX)
My Bad i didn't see that oil feed line hole on his turbo wasn't threaded for a 1/8 npt fitting . So i guess u need that flange with the an fitting on it or tap the turbo . But most turbos come with that oil feed line hole threaded already right ?
Modified by Civic Power at 10:16 PM 5/5/2004
Old May 5, 2004 | 11:59 PM
Cramerox's Avatar
Default Re: how to attach my oil feed line?K26 turbo (Hoosier Daddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy &raquo;</TD></TR><TR><TD CLASS="quote">
That's a return flange </TD></TR></TABLE>
I think he just ment you need to buy a flange....find the right flange problem solved.
Old May 6, 2004 | 12:35 AM
jure's Avatar
Default Re: how to attach my oil feed line?K26 turbo (Cramerox)
Thanx, guys you are awesome.
mattcalica
Aug 16, 2003 06:20 AM
reignofchaos
Jul 31, 2003 07:48 PM
TORQUE MONSTER
Sep 29, 2002 05:55 PM
Dancing is Forbidden
Sep 25, 2002 09:32 PM
