Fully break in motor before tuning?
Old May 5, 2004 | 09:57 AM
PolySquared's Avatar
Default Fully break in motor before tuning?
I just got my pistons and rods installed, but I need to tune my turbo b18. Should I drive my car untuned for the next 500-100miles or just get it tuned?
Modified by PolySquared at 7:08 PM 5/5/2004
Old May 5, 2004 | 11:28 AM
APEX CRX's Avatar
Default Re: Fully break in motor before tuning? (PolySquared)
if it was me I'd get it tuned then break it in
Old May 5, 2004 | 12:56 PM
VtecDeMoN's Avatar
Break it in and then tune it. I'd suggest ensuring the longevity of your motor by ensuring it is broken in properly before you try to tune it. Also if you tune on it you'll probably be more likely to rag on it before the break in process is finished.
Brian
Old May 5, 2004 | 02:18 PM
APEX CRX's Avatar
Default Re: Fully break in motor before tuning? (VtecDeMoN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecDeMoN &raquo;</TD></TR><TR><TD CLASS="quote">Break it in and then tune it. I'd suggest ensuring the longevity of your motor by ensuring it is broken in properly before you try to tune it. Also if you tune on it you'll probably be more likely to rag on it before the break in process is finished.
Brian</TD></TR></TABLE>
would it not make sense to tune a turbo motor first before running it for 100 miles not knowing if its running correctly especially on new internals?
Old May 5, 2004 | 02:24 PM
NIAScrew2's Avatar
I would break it in without turbo then install turbo and tune
Old May 5, 2004 | 02:53 PM
Kal's Avatar
Kal
Default Re: (NIAScrew2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NIAScrew2 &raquo;</TD></TR><TR><TD CLASS="quote">I would break it in without turbo then install turbo and tune</TD></TR></TABLE>
Old May 5, 2004 | 03:22 PM
Default Re: (Kal)
Hmm, its too complicated to take off the turbo and run stock n/a.
Old May 5, 2004 | 04:46 PM
S9i1R's Avatar
Default Re: (PolySquared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PolySquared &raquo;</TD></TR><TR><TD CLASS="quote">Hmm, its too complicated to take off the turbo and run stock n/a. </TD></TR></TABLE>
is it more complicated than rebuilding your motor again?
I'd run n/a or REALLY REALLY LOW boost until you have it broke in and tuned
Old May 5, 2004 | 09:42 PM
VanHonda's Avatar
Default Re: (S9i1R)
I have broken in motors with turbos installed without a problem. As long as you keep it to low boost, then it can actually help to seat the rings. As far as tuning, I'd wait until the motor is broken in then tune it.
Craig
Old May 5, 2004 | 11:41 PM
Default Re: (VanHonda)
Good news
Old May 5, 2004 | 11:51 PM
MiraiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VanHonda &raquo;</TD></TR><TR><TD CLASS="quote">I have broken in motors with turbos installed without a problem. As long as you keep it to low boost, then it can actually help to seat the rings. As far as tuning, I'd wait until the motor is broken in then tune it.
Craig</TD></TR></TABLE>
Old May 7, 2004 | 03:03 PM
TurboTeG4's Avatar
Default Re: (MiraiZ)
Leave the turbo on even with stock fuel system untuned and just dont make boost simple as that
Old May 7, 2004 | 04:21 PM
d16y8turbo's Avatar
i'd get it tuned right away. raggin on the engine for the first 15 miles to tune it is much easier on it than driving it around untuned for that long. plus, my guess is that you're probably gonna try hitting it at least once in the next 500-1000 miles before it's broken in. better tuned than not. plus, look at places like inline pro. they just idle the car for like 15-20 minutes than rack it up on the dyno. it works.
Old May 11, 2004 | 11:09 AM
Default Re: (d16y8turbo)
I just put a littler over 600 miles, you guys think i'm ready to be tuned?
Old May 11, 2004 | 10:50 PM
Sector9guy's Avatar
http://www.importbuilders.com/breakin.html
Good info. for break-ins. from the guys who build em.
Davidls
May 8, 2010 04:13 PM
95BlkGSR
Nov 30, 2004 01:05 PM
danl
Oct 5, 2003 06:14 PM
ArizonaTurbo
May 6, 2002 12:51 PM
