Differential Free spins
I was wondering if anybody had any idea if a d16a6 has a pin that runs through the differential gear that ends up driving the axles.
What happened was i was going around a corner and it just stopped moving, no noise, no catching. I have all gears so it is not a select fork in the tran. The differential is also spinning because the speedometer is run off from the diff. and it moves normally.
Any information would be appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apollo »</TD></TR><TR><TD CLASS="quote">I was wondering if anybody had any idea if a d16a6 has a pin that runs through the differential gear that ends up driving the axles.
Any information would be appreciated. </TD></TR></TABLE>
A differential will usually make a good bit of noise when it gets to the point the car wont move. I'd take a close look at the axles.
darkwater_ghost
Transmission & Drivetrain
Jan 3, 2013 11:31 AM
shai x boi racer
11
Oct 20, 2005 05:54 PM
