tial wg 38mm spring..help..
anyone?I'm totaly confused, I would like to run about 15psi of boost..anyone know where i can get another spring if this is wrong..
TIAL Big Blue Spring 1 Bar, 14.5 PSI
TIAL Small Blue Spring .8 Bar, 11.60 PSI
TIAL Small Green Spring .65 Bar, 9.43 PSI
TIAL Small Red Spring .45 Bar, 6.53 PSI
TIAL Small Yellow Spring .3 Bar, 4.35 PSI
looks like u have the small yellow spring which is 4.35 psi. Maxing out your boost controller i dont think you'll be able to hit 15psi.
Not to jack your thread, but I never knew there was a "maximum" psi you can boost with springs. I thought they were only for the minimum. Anyone know how much I can boost with a .5psi spring?
damn
What spring do you recommend me for boosting around 15 psi, and where to buy this ******* spring..I'm angry cause I'm from Europe..
try it with the yellow one first and see where you are at. If you need a spring let me know i have a few here. red blue green and big ones as well
will you ship in europe?..and I how much costs shipping with express mail delivery like fedex, dhl to europe..
and another question, how much psi can handle greddy type S bow?
Modified by jure at 9:49 PM 5/4/2004
I read somewhere that to get your wastegate max spring pressure you multiply it by 2, and add half of that.
So if you have 5 psi spring. Max spring pressure would be 15 psi... Can anybody confirm this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy »</TD></TR><TR><TD CLASS="quote">So if I have a .5 bar spring, even with a MBC I can't boost much more than 1bar?
Well if what I read, and posted is correct then yes you can NOT boost more then one bar with that spring...
</TD></TR></TABLE>Well if what I read, and posted is correct then yes you can NOT boost more then one bar with that spring...
40mm TiAL
.25 bar / 3.63psi / small yellow
.4 bar / 5.80psi / small red
.5 bar / 7.25psi / small green
.6 bar / 8.70psi small blue
.7 bar / 10.15psi / big yellow
.8 bar / 11.60psi / big red
.9 bar / 13.05psi / big green
1.0 bar /14.50psi / big blue
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic »</TD></TR><TR><TD CLASS="quote">I read somewhere that to get your wastegate max spring pressure you multiply it by 2, and add half of that.
So if you have 5 psi spring. Max spring pressure would be 15 psi... Can anybody confirm this?</TD></TR></TABLE>
so then you would just multiply by 3, because half of a number multiplied by two is the number you started with.
I am pretty sure that that is a large yellow tial wg spring. That is .7 Bar (10.15 psi). That should be good for anything up to 20 psi
Take a measurement of the height of that thing and I can measure my extra one.
Modified by tthame1 at 12:50 PM 5/5/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FwdCivicHatch »</TD></TR><TR><TD CLASS="quote">
so then you would just multiply by 3, because half of a number multiplied by two is the number you started with.</TD></TR></TABLE>
Duh! Why didn't I figure that out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 »</TD></TR><TR><TD CLASS="quote"> TIAL Big Blue Spring 1 Bar, 14.5 PSI
How sure are you of those colors? I'm reading something different on each site. I have a Green spring, not sure if it's considered big or small. Importparts said it was a .5, and a few other sites say it's .5, but i'm reading in your post and on other sit'es that it's .65.
viren, i do not see how the wastegate spring has much to dow ith the max one can boost. I always have thought it was solely dependent on downpipe and wastegate size... Maybe max safe boost because the wastegate gets stuck open? *confused*
Modified by 94goldjungsr at 11:53 PM 5/6/2004
0TT
Dec 7, 2007 01:37 PM
eg:R
Mar 6, 2006 01:15 PM
gdrum
Feb 24, 2004 01:55 PM
